Let me try to help... you've been a member of this forum for 4 years and we appreciate your being a member of our forum.
First lets take a look at the tool.
Mytee S-300 Tempo Carpet & Upholstery Extractor
Sub-compact carpet extractor with full-size performance!
Your search for an affordable carpet and upholstery extractor is over! We’re excited to introduce you to the Mytee S-300 Tempo Carpet & Upholstery Extractor – a lightweight, non-heated carpet extractor that has the muscle to remove oily, greasy stains from carpet and upholstery. The Mytee S-300 Tempo Carpet & Upholstery Extractor is perfect for the homeowner or weekend detailer that doesn’t require a full-size hot water carpet extractor.
Lightweight, powerful and versatile - that's the Mytee S-300 Tempo
Not all carpet extractors are created equal! Mytee has been in this business longer than most people have been detailing and they know a thing or two about how to build a quality carpet extractor. Built tough with Mytee’s roto-molded housing and equipped with a 3 inch stainless steel hand tool, the Mytee S-300 Tempo Carpet & Upholstery Extractor has features you typically wouldn’t expect on a carpet extractor in this price range.
The Mytee S-300 Tempo Carpet & Upholstery Extractor features one of the most powerful motors in its class. The single 2-stage motor produces a whopping 85 inches of water lift and the 1.5 gallon solution and recovery tank enables you to clean large areas before having to refill right away. The 8 foot vacuum and solution hose combined with the 25 foot power cord gives you plenty of reach so you can stretch across interiors without having to reposition the machine.
The Mytee S-300 Tempo Carpet & Upholstery Extractor is compact and lightweight, making it ideal for the mobile detailer. The unit itself only weighs 24 lbs and it can easily fit into the trunk of most vehicles.
Quit struggling to clean carpets and upholstery the old-fashioned way and step up to a Mytee S-300 Tempo Carpet & Upholstery Extractor.
Here's pictures from the Autogeek.com store site
Now on to your post...
I purchased a Mytee S-300 for mobile work.
First question: Did you purchase this product through Autogeek? It doesn't matter if you did or not as I'll try to help no matter what but just to confirm.
When it arrived the cap on the capture tank was in pieces. It was immediately replaced by the distributor.
It sounds like you contacted them and they replaced the broken part. My guess is maybe it broke during shipping? Who knows but the fact that they replaced it with no other details from the outside looks like good customer service on MyTee's part.
On the first use of the machine for a job, after about 5 minutes of use, the hose began to come apart. I cut off the separated section and continued. I have found the hose continues to come apart. I have taped the entire length with duct tape as a temporary fix but it is far from a professional look.
The junctions of the hose also have begun to pull apart with any pressure on them now that the weather is warmer.
Question: After the first use of the machine, when you first discovered there is a problem with the hose, did you contact MyTee to let them know about the problem?
If you did, what did they do or say?
If you didn't, how long did you wait before you contacted them about the problem that started with the first use?
I've never had any sign of the hose breaking apart on the units in our garage and the plastic material they are made from is actually a pretty stout material.
Can you take a picture of the areas that are breaking and post them to this thread or send them to me and I'll post them to this thread.
[email protected]
Even with the new cap the dirty water continues to leak making it not practical for use in a large SUV where the machine must be placed in the vehicle in order to reach.
I don't have a Mytee S-300 Tempo Carpet & Upholstery Extractor out of the box but it looks like it has the same cap out 8070 unit has. This is a plastic cap that mates to a plastic outlet. There is no gasket so you must tighten down to prevent leaking.
It's possible there's a bur or some other un-even surface between the cap and the outlet, perhaps check and use a fine file or some fine sandpaper to smooth it over.
I'll take the cap off the 8070 and when I'm at Lowe's this weekend I'll see if there's some off-the-shelf rubber gasket that fits inside this cap in the plumbing isle because this is really what any hard interface like this needs just to make it bubba-proof.
I sent an email to Mytee several days ago and have yet to receive any response.
I've been e-mailing since e-mail was invented and I try my best to answer all incoming e-mails within 24 hours and many of you that have e-mailed me know I reply back in hours. That said once in a while I completely miss one.
So no comment from me about anyone else's e-mailing protocols.
If this is the quality to be expected from the brand I cannot ever justify spending over $1000 for a bigger machine, particularly if their customer service is going to ignore me if there is an issue.
The leaking cap is annoying I'm sure, especially if you're placing the unit "in the vehicle" and I "think" the right answer is for the company to include a rubber gasket with any model that uses this style of sealing the dirty water tank. At least a rubber gasket would or should ensure minimal risk for leaking but in the big picture this is kind of a small detail.
As for the other points you make, they did send you a replacement cap and hopefully you'll get a reply to your e-mail.
