I just got some Menzerna 4500 to follow MG 205. I'm using Flex 3401 and have LC white and black pads.
It's my first time with the 4500. Any suggestions on how I should apply it??
Thanks
Did you purchase the 4500 with the purposefulness to 'jewel the paint'?It's my first time with the 4500. Any suggestions on how I should apply it??
I would normally go with black also. SF 4000 and 4500 are both similarly fine grades of finishing polish. The 4000 has just a bit more cutting ability. If that doesn't quite do the trick you can then try the white pad. There is a menzerna chart in the website that helps with the pad decision. Also not sure which green or blue pads your talking about. Lake Country?
Sent from my Nexus 7 using AG Online
