N914 As Panel Prep
mudhog79
Using the search i see a good bit of info on using the above as a WW or RW. For the panel prep i know it is supposed to be mixed 1:8 concentrate to water. But what is the best way to apply it? Spray it on and wipe it off after a short period of time or do i rub it in or what? If you do rub it or buff it what is best to use?
Thanks
There is not special rubbing or wiping required.
Spray it on the panel and wipe it with a microfiber towel.
The 1:8 ratio makes a excellent wheel/tire cleaner as well.
IMO the best cleaning Rinseless wash I have ever used. Especially on wheels/tires.
Sent from my LG-LS777 using Autogeekonline mobile app
The following is my panel
wipe/prep routine:
1.) I spray the panel-wipe solution
onto the microfiber towel (trying
to avoid overspray);
2.) Next, using the dampened MF-towel:
I gently wipe off the unwanted sub-
stances from the panel. (Gently, to
avoid inducing any marring to the
just polished paint)
3.) I then use a different, clean-and-dry,
MF-towel to gently wipe away the
remnants of the panel-wipe/unwanted
substances aggregation.
Repeat processes on each panel 'til
mission's completed. Eazy Peazy... :xyxthumbs:
Use plenty of MF towels. It will streak if you don't.
I like N914 as a WW and RW, but use another product for a panel wipe.
