No problem. I will put together a full review with video on them.
Looking forward Mike
I had a vehicle the other day that had so much road tar on it that it cost me an hour and a half just removing that. I'd like to find a faster way to decon all of that crap. Maybe this will help!
Looking at getting the nano skins clay sponge and some Optimum Rinseless to use as lube. Should I get the fine grade or medium grade sponge?
I've never used one of these, and have been thinking about getting one, as I hate to use clay. My question is, is it the same as using lube for clay?
I love the sponges. What I do is use the wash bucket solution as a lube. I fill the sponge with soapy water and squeeze a little bit of it on the paint then flip the sponge to the clay side and clean away. It's very efficient and it does a great job. Then I just rinse the whole panel when I am done with the hose. Takes about 30 mins to do the whole vehicle that way unless there is heavy contamination that requires repeat passes.
As for fine or medium, there is usually a dual pack available with both of them. That is what I purchase. I start with fine and if it's not enough I switch to medium. If that still won't remove the contaminant, then magic eraser will do it. Just have to be ready to do a quick polish if you use the magic eraser though.
Never used the disk. I would imagine it would work just a s well, if not better. Seems like it would be hard to get into the finer areas
Darrin
