cant remember when i used clay last. nanoskin has changed my life.
does nanoskin strip sealant or wax?
Nanoskin AutoScrub Fine Grade Wash Mitt
Not sure if it does like clay, stripping sealer and waxes. But anytime i smooth any service i lay down an AIO .
What is a baggy test?
Used my Cobra Clay Mit (nanoskin) for the first time today as opposed to the clay and WOW, it's easier to use, just wash it out and keep going, no kneading or worrying about rubbing old contaminates into the paint and it is a much faster process. I was taking off black paint over spray and you can feel the paint coming off with the Cobra mit just as easily as you did with the clay.
I'm with a lot of you out there in putting my clay on the back shelf in favor of the nanoskin pads.
Red
The efficiency between clay and the clay alternatives is HUGE.
Yes, they will marr the paint more, but if you're gonna polish after, doesn't really matter. If you're not going to polish after, I'd be hesitant to use clay alternatives.Does it cause much marring? When I tried the Speedy Prep Sponge I had terrible results. No matter the type or amount of lube I would lay down I had horrible marring, especially on vehicles with soft paint. After a few tramatic uses, I went back to clay.
