chilly
- May 13, 2006
- 2,971
- 762
I purchased a new fine grade Nanoskin Autoscrub Wash mitt in June and used it exclusively on the paint correction project for my new Lexus
I am 2/3 of the way around the car, a panel at a time, and earlier this week the mitt failed to remove contamination from the door I was working on
I changed my lubricant twice and it made no difference
After I finished I washed everything up and did my laundry, cleaned my pads, and hung the mitt to dry and when I went to put the mitt away I found this
The mitt has become so sticky I pressed my fingers down and it stuck so hard I could pick it up and shake it and it didn’t let go
I contacted Nanoskin and started a dialogue
They wanted to know what I had used for lubrication and I told them ONR WW strength with a bit of Gold Class which worked beautifully from day one and then I told them I tried a straight shampoo solution when it stopped working
They got back to me today and told me that based on other customer feedback that the issue was PROBABLY due to my choice of lubricant, that ONR or Gold Class had PROBABLY attacked the polymer
Or
It was down to me storing it WITH OTHER DETAILING PRODUCTS which MIGHT HAVE out gassed and destroyed the polymer
The advised me if I decided to try their products again to be sure to use their proprietary chemicals for lube and to store the mitt differently
The mitt was stored in its clamshell case, after being air dried, on an open wire shelf in a garage
I don’t think out gassing is the problem
And if ONR or Gold Class destroys polymers we are all doomed
Needless to say this is my last dealing at all with Nanoskin
No “we are sorry” or “that sucks, how can we help”
Just dumped it back on me with lame theories and blame
Rant over
Sorry to be so negative about the product but I am totally underwhelmed by their “customer service”
Or
Rant over
