Checking out the nanoskin wash mitt. Does anyone have experience using the bubble bath versus the Slick spray?
Had some very basic questions because i dont know much about detailing.
1. I want to apply a coating to an RV and my truck. Plan is to hand wash real good, then use the nanoskin mitt. Now before applying the coating dont i need to strip off the "shine" that the bubble bath or slick leaves behind? I seen some people recommend 50/50 water with IPA to get a virgin surface. Hard to picture myself doing that to an entire RV. The truck wouldnt take too long. Is there a nanomitt lubricant that does not leave a protectant? But instead removes contaminants and leaves behind a virgin surface? That seems weird to clay with something that leaves behind a protectant just to wipe that protectant off before applying a more durable wax or coating.
2. Is skipping the use of a DA or rotary a mistake in terms of how good the coating will stick? If i do use a DA and maybe a 1 step compound, do i need to wipe the entire surface with IPA before applying a spray on ceramic coating?
