Natty Paste Dusting?
NoleFan
I am having some problems with Nattys Blue dusting on my black vehicle. The first time I had a dry pad, just did the hood, and wiped off. It dusted, but not too bad considering I put it on too thick and didn't wait for it to dry.
Yesterday I did the whole vehicle. I wet the pad with an ONR QD mix,did the whole truck and then went back and buffed. This time trying to put it on thinner, but I had some horrible dusting going on.
What am I doing wrong? Am I still putting it on too thick? Maybe try some different microfibers? Let it dry longer?
Thanks guys & gals! :buffing:
hmm wierd only time I have had any dusting with any of the nattys (red, white, or blue) was when I have applied to much. Did you wipe off right away? I usually leave it on for a short period of time (15 min?)
I wouldn't wet the applicator with ONR or anything else. Just use a clean dry pad and apply it very thin. I usually do apply to the whole car and then start removing at the place I started. You shouldn't get any more then a wee bit of dust if any. If you are getting noticeable dust you are probably applying too thick. You could get a mf towel damp and after you've buffed off just dab the spots where the dust "piled up". Then next time just apply it thinner.
It was probably around 15 minutes. I started at the hood and worked my way around. Once I got done with the whole truck, I went ahead and took it back off of the truck starting with the panels it was put on first.
I followed it up with a QD final mist, so all was well. I just didn't know if this was normal for the product.
If you put it on any thinner, how can you tell were you were? ;)
I agree...the only time it dusted for me was if I applied too much product. I usually apply it to the whole car, then go back and wipe off the residue. I still have no issues with excessive dusting. I use plain old water to dampen the applicator pad. Try even thinner when you are applying it maybe?
I guess I just need to apply thinner. Less is more right.
Also, what pads are you guys using with Natty? I got the yellow foam pads from AG, but they don't fit into the Natty Jar, so I feel like I am only getting wax on a portion of the pads. Can I cut them down, or will the pads not last long that way?
I use a small 3" red applicator with a velcro backing. works awesome
