Whiplash Willy
- Jun 30, 2010
- 77
I have a couple of problem spots on my 2011 diesel Jetta, and had a few questions on the best way of safely cleaning them.
1. Exterior Rubber Window Trim
-The black rubber trim around my door windows is starting to turn a brownish color. Noting really comes in contact with the trim, and I wash it once a week.
1a. Do I need to clean this trim? (I have Optimum Opti-Clean and Power Clean, which would be best to use?)
1b. To protect the trim after cleaning, would it be best to use Aerospace303 protectant, or Optimum Opti-Bond Tire Gel (Optimum says it can be used on all rubber/vinyl surfaces)
2. Door Sills
-During assembly, they left behind gobs of grease around the hinge areas, and lower door sill areas, that is making a mess everywhere.
I was thinking of using either Opti-Clean or Power Clean for these areas. I worry about using Power Clean because it may be hard to rinse off the residue, but Opti-clean may be powerful enough. What would be the best to use, or should I be using a different product?
3. Rocker Panels
-The rocker Panels under the doors are covered with dirt, grease, road tar ect. The surface is painted over textured material. What would be best to safely clean this area?
2. Door Sills
3. Rocker Panels
