gencoupe3dot8
- Jun 6, 2011
- 20
I may have trouble with the smaller sections though, especially with the 6.5" pads. Any advise what I can do? Polish it by hand instead?
A few thoughts:
1) Look for smaller pads for your polisher.. if not available, considering getting a smaller back plate for a drill and like 4 inch pads, with a caveat that this will act liek a rotary and you will need to be VERY careful.. practice on a car you don't care about or a practice panel.. this also helps with RIDS.
2) Consider moving to a flex 3401 vrg (forced rotation polisher). Is has some of the action of a rotary (~400 rpm) and a DA (OPM)... this will speed up correction and get some defects you can't get with your current DA.
3) Wetsanding is likely not indicated given your current polisher (and perhaps experience level) As you gain experience you will eventually want to move to a rotary polisher (big caveat is you can burn through your clear coat if reckless with it.. causing you to need an expensive repaint, so use at your own risk, and try to use on an old beater or practice panels first). Your Menzerna polishes work VERY well with rotary polishers. You will most likely need a rotary to remove anything above 2000-2500 grit.
If wetsanding a paint thickness gauge is also likely in order.
Regards,
Mike
