i have no clue what im doing wrong with the megs swirl x. ive tried using it 3 times now, with each time not removing all the swirls. im using a PC 7424xp with a LC ccs coarse green pad. im doing exactly what you are doing in the video. put the x on the pad and with the buffer on 3 quickly spread the megs into about a 2x2 area. then turn the buffer up to 6 and use moderate pressure for 3-5 or until its broken down. so broken down is until its "dry" or you cant see it anymore?
also, what pisses me off the most, is as i was making my last attempt at swirl removal, the velcro on the pad came off and seperated from the pad itself. is there anything autogeek can do or am i screwed? ill get a pic tomorrow.
one more thing. i got the dual xenon light in my last order in order to make it easier to find swirls. for some reason im not seeing anything, and i know theyre there becuase i can see them under the sun and even better under those lights that have the sulfer bulbs. any help is greatly appreciated. thanks
