Hey everyone,
So I've been using the original PC 7424 for any and all customer's cars for the last 5 years. I've always achieved great results with it, and learned how to use the machine just right to get the results I needed. This usually consisted running the machine on 6, holding the machine firmly with little pressure. Once the compound broke down, I'd lower it to 4, and lay into it with jsut enough pressure to keep it rotating. This, usually, left me with results that I didn't even need to follow up with a finishing polish.
I bought the Rupes MKII 21 towards the end of last year, and I've had 2 chances to use it so far - once at the end of the season, and a few days ago since it has warmed up. Both times I've put it back down and picked up my 7424.
Using the MKII, Rupes Yellow pad, and Menzerna FG400, I was working on the door of a 2012 Camaro - fairly flat.I think I had the machine somewhere between 5-6. After spreading it around, I slowly moved across the panel. I noticed that, while viewing my reference line on the backing plate, that the machine was struggling to rotate sometimes, it even began rotating in reverse at one point. I never have a problem keeping my 7424 flat, but the the 21, apparently I do. After doing my "high speed" pass, I slowed the machine down and added a bit more pressure. Once I went to buff the remaining FG400 off, it was nearly baked on there. I had to really press the towel into the door to remove it, and it was a bit chalky. The pad surface felt warm and almost gummy. I also found that it hopped quite a bit with the Rupes yellow pad. I actually found it easier to use with the LC flat pads that I use on my PC. Perhaps I'm just not used to the machine, or the stiff Rupes pads. I'm also accustomed to using my PC as an all around tool, where I feel like the Rupes 21 isn't going to work well in some areas, like where the lower door meets the rocker panel and other tighter spots.
I'm definitely disappointed. To spend around $400 for a machine, and still reach for my old outdated PC is a bummer. But, I do understand that I have a lot of time on the PC, and plenty to learn about the Rupes - so I'm not giving up on it yet.
Tips and advice is much appreciated. Thanks!
