Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
New: 1-Pad Polishing System from Lake Country
Look what came special delivery today... the new final production 1-Pad Polishing System from Lake Country.
Eric Dunn and Lake Country set us two sets of everything, one set to test out and one set to take to SEMA so if you're going to SEMA be sure to stop by the Autogeek Booth and check them out...
Autogeek at SEMA Information
Note: The target market for this new pad system is for high-end detailers that tend to only use new clean pads for each detailing project they tackle. There is a learning curve to this new pad/backing plate system but once you get accustomed to the thinner foam pad with the cushioned backing plate you can achieve results like a pro.
Here's the complete 1 Pad System but it's actually two lines in one... there's the 1-Pad System which includes the wool pads and the CCS Foam Pads with a *New* Hybrid Orange Cutting pad and there's the two pad, Hydro-Tech foam pad system for people that love the Hydro-Tech foam formulas.
1-Pad System which includes the Wool Pads and the CCS Foam Pads with a *New* Hybrid Orange Cutting pad
The Two Pad, Hydro-Tech foam Pad System
The entire system is patented and centers, (no pun intended), around the unique patented Tri-Density "Cushioned" Plate.
The upper yellow backing is high density foam, the black core is medium density foam and the red face is low density foam.
The backing plate is very flexible...
The red low density foam is very soft and pliable...
It also compresses easily under pressure...
Total width of the backing plate is approximately 1 1/4"
The Velcro interface measures approximately 5 3/4" in diameter and the overall width is approximately 6 1/2" in diameter.
Turning the pads over you can see the form fitting shape
The Velcro Interface on the back of the wool cutting pads measures approximately 4 3/4" in diameter.
Here again you can see the bowel shape design of the back of the pads that helps to self-center the pads onto the backing plate.
The hook-n-loop interface measures approximately 3 5/8" in diameter.
