Did they really feel the need to add CCS to the hydro-tech pads?
I bet the pads will cost more than one should think. A 4-in pad costs like $5 to $6 so I doubt it would be much cheaper since you have a certain amount of foam.
If you are running a shop where labor is well over $20/hr (burdened) then it does make sense to not spend a lot of time cleaning pads ($10 for a pad, $5 labor to clean, dry, etc) then it could make sense.
If you were to buy a set of disposable pads for EACH car that came through! say you needed 4 pads total per car each at $5 a pad. Thats $20 a car your investing in for pads.... you do 4 cars a day in that shop and you spent $100 dollars on pads just for that ONE DAY.... then need to pay for AGAIN the next day....
Since it seems I missed the end of the edit window, I'll continue here:
The ONLY real concern I would have from a marketability standpoint is that they're creating a system of consumable items that may actually increase the amount of refuse generated by an active detailer who uses large quantities of pads. Not very eco-friendly.
However, I suppose the argument could be made that since these are being marketed to the type of people who may already be throwing traditional pads away after a single use, 1-Pad decreases the amount of "waste" by 65% over their current buffing system.
It's really a double-edged sword, this system. It will be interesting to see how well received it is once it actually hits the market.
