New Blackfire Pro Coating + SiO2 Spray Sealant + Pinnacle Jeweling Wax
The Guz
Looks like the new BF coating is out. Hopefully this is the redesigned version. The bottle looks nice.
BLACKFIRE Pro Ceramic Coating, BLACKFIRE Crystal Coat Paint Coating
BLACKFIRE Pro Ceramic Coating is unlike any paint coating ever before seen in the BLACKFIRE line. Designed to provide up to 2 years of protection, gloss, and depth, BLACKFIRE Pro Ceramic Coating creates a hard barrier between your paint and the elements. Using advanced ceramic paint coating technology, BLACKFIRE Pro Ceramic Coating was designed for easy application both by detailing enthusiast and professional detailer alike. Keep your paint protection, shining, and repelling water with unparalleled longevity with BLACKFIRE Pro Ceramic Coating.
BLACKFIRE Pro Primer Polish
BLACKFIRE Pro Primer Polish is a non-abrasive, non-solvent polish used to prep your paint for the proper bonding of paint coatings. Designed to be use in conjunction with BLACKFIRE Pro Ceramic Coating, BLACKFIRE Pro Primer Polish uses advanced ingredients to remove all types of compound oils, previous waxes and sealants, and anything else that will prohibit the coating from performing its best. If you want the best results with coating with BLACKFIRE Pro Ceramic Coating, you’ll need the BLACKFIRE Pro Primer Polish first.
BLACKFIRE SiO2 Spray Sealant
BLACKFIRE SiO2 Spray Sealant is the easiest spray sealant you’ll ever use! Designed with a spray-and-wipe application on wetted paint, BLACKFIRE SiO2 Spray Sealant provides long-lasting protection thanks to the unique SiO2 chemical make-up. BLACKFIRE SiO2 Spray Sealant, typically used to extend the life and water-beading capabilities of your existing paint coating, can also be used as a stand-alone protection product. BLACKFIRE SiO2 Spray Sealant was designed with the professional detailer in mind and allows for quick application and long-lasting results.
Possibly a replacement for the BF AIO Tire & Trim
BLACKFIRE Multi-Surface Dressing Concentrate
Keeping in line with the rest of the BLACKFIRE line, BLACKFIRE Multi-Surface Dressing was manufactured and designed with professional detailers in mind. This concentrated formula let’s the user decide the level of gloss, while still providing long-lasting, exception results. Featuring a versatile formula, BLACKFIRE Multi-Surface Dressing is used on leather, rubber, plastic, and even engine components, providing everything from a high shine to a muted stain finish.
Also a new Pinnacle product.
Pinnacle Souveran Jeweling Wax
From the same line that brought our number 1 carnauba paste wax, comes the newest in the Pinnacle Souveran line-up – Pinnacle Souveran Jeweling Wax. Designed as a light cutting, one-step cleaner wax, Pinnacle Souveran Jeweling Wax uses advanced abrasive technology to correct light swirls and scratches from painted surfaces and shine them to perfection. Pinnacle Souveran Jeweling Wax creates an intensely deep, wet shine and will protect your paint after just one use.
Guz
Sure hope you get to try them and share your input, I would not mind test the products as well
Got excited about the BF dressing for a second, but appears that it is just a pure dressing and has no cleaning properties according to the description and the front of the bottle. Unfortunately not a replacement for Trim & Tire AIO. Seems like more of a competitor to PERL.
Other products are interesting but I'll wait to hear reviews first (especially the coating).
Hope they price it right..most of their offerings are bit pricey..
I got excited too someone needs to re release that product. Who cares about another coating product we already have a million of them to choose from.
I’ll definitely be trying these out. I did not have such a great time with the previous blackfire coating.
Happy to see the BlackFIRE Coating make a return to the line. I had good results with the first generation product although I saw many users have troubles with it. Hoping to see more positive reviews of this fine product.
I would like to see an Si02 wash go along with it.
They just put the prices out.... Ouch!
I'm guessing (with the exception of the coating obviously) these are all 32 oz. versions like their other products in this new line that's marketed to professionals. Unfortunately the size isn't mentioned on the product pages. So probably doesn't make sense for the average hobbyist to buy some of their products at that size (like a $60 bottle of primer polish!). But at $48, a 32 oz. bottle of the spray sealant isn't a bad deal when you compare it to a product like Reload that goes for $35 for ~19 oz. or $25 for 8 oz. bottle of Opti-Seal. Probably not something the average guy will buy but I guess not a bad deal if you are a pro.
I thought the pinnacle jeweling wax was expensive looks like a small bottle
Been awhile for a giveaway. Lets have one and get these products out and tested with reviews.
Where did you see the prices posted?
They updated price few hours ago in Whats new section but looks like they removed it again..anyways they are very pricey so not for me.. I just work on my personal cars..
To answer a few of these questions, yes all the prices are listed. The Pinnacle product is 16oz and the Blackfire products are 32oz.
The Blackfire Ceramic Coating is completely different than the previous coating, it is 50ml and we have priced it way below all the other 50ml coatings.
These will all be available soon along with a few other "surprises"!
The price on the coating is right on the money. Especially if you truly get the professional grade results. At 50ml you should get 2 vehicles from it depending on how well it spreads.
50ml should work for a mid-sized SUV wouldn't it?
My only issue with a 50ml bottle as an enthusiast is the lifespan of the product once the seal on the bottle is broken. If the shelf life is only a few weeks like some coatings, it would be a non starter for me as I am never able to do multiple vehicles back-to-back over a series of consecutive days like those who run a shop.
I really hope this coating does well for Blackfire and PBMG. The previous version was a disaster for me, but I'm willing to get it a second chance. I hope there will be a sample size available in the future. I'd be more than happy to buy a 10ml-ish bottle to try it out.
I'm a little disappointed to see the only prep product is a polish since Blackfire used to have a coating prep spray. Personally, after I've already spent the better part of a day doing a one, or two-step correction on a vehicle, the last thing I want to do is have to go over it yet again with a polisher to prep for the coating. I'm a huge fan of the prep sprays. Hopefully this coating will still perform well using alternative products like Prep, Eraser, etc.
Absolutely 50ml will probably do 2 mid size SUVs. Again depending on spread ratios. For instance the IGL coatings require 2 layers and I can easily do 2 vehicles with a 50ml bottle. As for shelf life I will be curious too.
