New Gas Grill Needed
ScottB
Ok ... its time to replace the Brinkmann Gas Grill we have been using for the past several years. I really dont want to spend an arm/leg for something kept outside (its covered) but used 2-3 times weekly when possible. I was thinking about the newer Infrared Technology like the Quantum models but hear cleaning it is needed frequently. Should I just grab the current sale model at Lowes or Target or is there something hiding in grilling that might be missed.
So whats everybodies grill of choice ... and yes I realize there also smokers and charcoal, but prefer gas personally. But always willing to listen.
I have a Weber Gas grill and it's the best one I've ever owned. It's very well designed and it's construction if top shelf. I've had it for about 5 years and other than replacing the grill grates not one problem.
Be it gas or charcoal, you can NOT go wrong with Weber.
I have a Kirkland( from costcos) Have had for about 8 yrs...look at the burners in the grill.Srtaight tubes are readily available.My Kirkland tubes and deflectors will run me about $400 to replace,and they need it now so I'm in the same boat as you looking for something new that I can repair without spending more than the grill is worth.
I cook on our grill almost everyday during the summer and in the winter months its at least 4 times a week.So I'mhard on one .Look around at different units and then look at replacement part cost...just a suggestion!
Hope you find one soon and call me when its dinner time!!!! :D
Another Weber vote. Porcelain hood looks sharp forever (go ahead, use your Flex to polish), and when it needs some TLC, parts are available and easy to find, often locally.
Mine is pushing 15 years. Just getting started.
Weber-Stephen Products Co. makes about the best engineered and constructed grills on the market. They may cost more but you don't need to replace them every few years. My neighbor has gone through two cheap gas grills in 8 years and his current model needs around $300 to use this season. He's spent more than I have on grills and is now looking for another new one.
I chose this Ducane Meridian, (Ducane is a Weber-Stephen Products Company) and I absolutely love it.
Another vote for Weber...the Genesis Series...Ask your local Weber dealer about the upgrade to stainless cooking grates and flavorizer bar. There should be a Weber dealer in your area---buy your new grill there, if you can.
Weber Grills and Accessories {Just double click on the map} :)
Reviews of the Charbroil infared quantum are not too good. A lot of people are saying it rusts and replacement parts are needed after only 2 years. Some are not a fan of the way it cooks.
I am looking at a grill too. Most people say they wish they spent the extra couple hundred and got the Weber.
Look up MHP grills. They are cast aluminum and will last forever, as well as guaranteed for life. I have one and I am sure it will be the last grill I ever buy.
I came here to share this exactly. I have a 15 year old Weber that is still working well.
I have a Weber Genesis and it's really great. Very high quality. We got the copper colored one.
I have this Char-Broil Infrared grill. I've had it for over two years and haven't had any issues with it, other than I don't get to use it as often as I'd like! I love that it cooks everything evenly without any flare-ups.
After we move, I'm looking forward to taking my P21S polishing soap to it! :buffing:
Mark
Weber hands down. Worth the extra money. I have the Summit 450. I take care of it and will have it for years to come. Built like a tank.
I also have a Weber Kettle for Charcoal and a Weber mini portable for tailgating.
My Weber is into year 13, stays outside covered in a winter climate and I use it all year round. The ignitor button that usually fails in the first couple of years went after 10 years! Weber has parts diagrams and ordering online, quick, easy and reasonably priced.
I can't think of any reason to buy anything else regardless of price.
TL
Whats wrong with your current grill? More then likely, it can be fixed for very little
If you're really set on a gas grill, I won't change your mind, BUT... I used to swear by gas - until I went out on a fishing charter and was introduced to the Big Green Egg.*
It smokes, roasts, grills and bakes. We even make pizza on it - which is out of this world delicious. It's as easy as a gas grill with MUCH better flavor and it's more economical. Just close the damper, cap it and use the same coals again and again (Yes, really.)
It's FAST - It's ready to cook in under 10 minutes and sears steaks to perfection at well over 1100F (where my thermometer needles out) - one minute per side for rare, or close dampers, cap and add another 60-90 seconds for a perfect medium rare. I've been spoiled - I won't order a steak out anymore.
It's SLOW - Fill the firebox, drop the indirect heat / pizza stone and grate in, adjust the dampers and it will hold 250F all night (7-8 hours) for the most awesome butt, shoulder or racks of ribs.
It's EASY - No messing with propane bottle filling or exchanges, valve/line connections, igniters that don't work, etc. No burners to scrub, no worrying about the elements or having to cover or store it. Very few parts - mostly worry-free heavy ceramic, plus the grate and cap/damper. Lights easily with a match and Fireballz / waxwood or electric starter - no 'starting fluid' ever!
CLEANING - Lightly brush the grill surface after cooking (or not) and close it up - use a half an onion on a grilling fork on the hot grill to clean the ash off and 'season' the grate next time you fire it up. For a real greasy mess, just throw the dampers open wide and let it burn itself out - there will be nothing but fine ash (no chunks) left - it's more or less self-cleaning. It's so efficient, I only have to clean ash out of the firebox after maybe the third or fourth regular use, or when I do a full-burn-clean. It's not at all like greasy, chunky briquette ash from a metal-pan grill - it's powdery-fine, and I usually just use my shop vac to suck it out of the bottom of the firebox. Use a damp rag to wipe off the glazed ceramic outer surface - no chemical cleaners are ever used inside or out. In twelve years I have NEVER had to scrub, scrape, soak or scour the inside of the BGE!
It's DURABLE - My Big Green Egg sits exposed to the elements year round and I've only ever had to replace the grill surface ($20-24) and the firebox grate ($18) due to wear and tear over the 12 years that I've had it. All the ceramics are warranted for life, and with the exception of the weathered wood handle, it still looks and works like brand new. I do replace the felt lining around the lip occasionally - probably not as often as I should - but it's inexpensive ($11) and easy enough to do. It really is the last grill you will ever need (or want) to buy.
If you ever run across a BBQ competition in your neck of the woods, look for the team(s) that cook with the BGE and ask them about it. You'll get an earful - and more than likely some delectable samples!
*Sorry to sound like an infomercial, but even after more than twelve years, I really do love my grill that much! :hungry:
I wish Weber didn't buy Ducane. The Ducane I had lasted forever, but this Weber is definitely a step back as far as quality goes.
only way to go they last and can get parts any where
