New (& Improved) from Lake Country!
Elliot@Autogeek
CCS Foam Pads by Lake Country save polish and create less heat! CCS Pads feature unique collapsed cell structures that release product onto the pad's work surface as you need it. These little structures slow the rate of polish absorption so you can work longer without reapplying polish to the pad. Plus, CCS Pads create less heat and prevent pad skipping.
Each CCS Pad measures 7/8" of an inch thick, perfect for even distribution of heat and product. The CCS Pad's tapered edge was designed to optimize performance, regardless of the type of machine used.
The Lake Country CCS Pads feature a "Simple 6" idea. This easy to understand system keeps your pad colors and uses consistent throughout the CCS and Flat Lake Country Pads.
All in all, CCS Pads are some of the most technologically advanced buffing pads on the market. Multiple sizes are available ranging 4 inch spot buffing pads to 8.5 inch rotary polishing pads. As always, CCS pads are made with Lake Country's proprietary foam compositions that deliver dependable paint-correcting performance with every detail.
Lake Country CCS Pads New & Improved!
Lake Country Flat Pads are the classic 6.5 inch foam pads with flat, full contact surface. These are still some of the best pads you can use on your 6 inch dual action polisher. Lake Country's durable foam compositions minimize heat build-up to protect the paint. The hook and loop backing covers nearly the entire back of each pad, providing a secure hold on the backing plate. The flat pads are excellent for large, flat panels. The foam stays in contact with the paint so you can work efficiently. Choose from multiple foam compositions.
Lake Country Flat Pads feature a thickness of 7/8" of an inch, as well as a reduced bevel for the perfect balance and control. The smooth feel and performance of these newly refreshed Lake Country Flat Pads allows for the perfect alignment of your backing plate for an overall increased experience.
The Lake Country Flat Pads feature a "Simple 6" idea. This easy to understand system keeps your pad colors and uses consistent throughout the CCS and Flat Lake
Lake Country Flat Pads New & Improved!
Yes - thought the same thing. Helpful for sure!
I just received (18) of the new LC Flat 5.5" x 7/8" and that 1/8" of a difference from the old 1" pads makes a nice difference. The pads rotate better and seem easier to polish with.
ScottH
