NEW! Lake Country Wool Pad Spur
Meghan
Super Moderator
Remove caked-on polishes from wool pads in seconds!
Keep your wool pads in working condition with Lake Country Wool Pad Spur. This unique tool removes caked-on polish from the wool pad on the fly so you can continue polishing. Save time and maintain pad performance with the Lake Country Wool Pad Spur.
autogeek_2102_135731647
Lake Country Wool Pad Spur!
If you use wool pads, you need a spur.
It works so much better than what guys normally use that don't have spurs and that's screwdrivers.
A spur will remove built-up product residue and removed paint and it will also help to re-fluff the fibers and it wont' tear up the pad like a screwdriver or some other instrument will as the star shaped spurs rotate on a axle.
Also, if you have a pad washer, either the Grit Guard Universal Pad Washer or the System 2000 Pad washer, after cleaning a wool pad in the pad washer it's a great idea and my own personal preference and practice to then spur the pad with a Spur to re-fluff the fibers and even remove any residual water/cleaning solution off the pad.
This is a must have tool. These tools work great and I wouldn't be without one.
