New Meguiar's DA Microfiber Correction System Video
This question cannot be accurately answered via the Forum
ONLY a Test Spot will reveal the combination of: pad, compound, polish, machine speed, downward pressure, number of passes.
Yes allenk4, i understand that, but i believe there is so many of you have already test it, right? Hehehe
I just want to know, which one is have the best result
D300+D301
Or
Ultimate Compound +Ultimate polish +Ultimate liquid Wax?
And @The Gus suggested me to add ultimate wax after d301
Do you have any other suggest?
Sent from my GT-N7100 using Tapatalk
It's not something where we can say step 1 do this, step 2 do this and so on. Each car is different and the paint reacts differently. That is why we all recommend a test spot. Let the paint tell you how it reacts.
This is what you had posted
Hi guys, need your oppinion, which one will get best result to get shiny white car?
1. D300 w/ mfcutting pad + D301 w/ mf finishing pad
Or
2. Ultimate compound w/ cutting foam pad + ultimate polish w/polishing foam pad + ultimate wax w/ finishing foam pad
I only have that. Should I add more items too get shiny white car?
It seems that d302 not ready in my country, Indonesia.
Again go with a test spot with the least aggressive product whether it be UP and a polishing pad or D301 and a MF finishing disk.
My personal recommendation is using UP+foam polishing pad to start. Move up in aggressiveness if UP is not giving you the desired results.
I also recommended using UW as your LSP and not D301. Due to UW offering longer protection.
If you want to do a 2 step procedure with the DAMF system then you could top D301 with UW after a 12 hour window. But I would start with a test spot before going this route.
Don't over think it.
