New Menerna Polish (Power Finish (PO203S)
TOGWT
SELF BANNED
Power Finish (PO203S) - (M) this is a a one-step scratch remover polish that will remove 2500 grit, cut 3.0- gloss 3.0, Slightly more abrasive then PO 106 but produces a burnished finish (for black or dark coloured paint surfaces use as part of a duel level foam pad / polish system PO 85 RD 3.01 Super Intensive Polish) 1500 RPM - primed LC Orange / Green (mid range, high density foam (60 PPI) medium abrasive cutting action) or a White primed (softer less dense foam (70 PPI) with a light abrasive cutting action)
* Cut is between SIP and 106
See also Polishing - Menzerna Polishes -http://detailingwiki.com/index.php5?title=Polishing_-_Menzerna_Polishes
Going to be testing it out this weekend....detailing a red 3000GT, a black '08 Passat, and a black IS250.
If you would, please let us know how you like it.
Could you also comment on its cut compared to SIP and Nano, its work time and which pads it works best on? Thanks.
yes please give your thoughts. I'm personally curious to see how it does on the Passat, especially if it has moderate swirls.
I'm interested in how well this works too. :cheers:
