New Menzerna Product !
Meghan
Super Moderator
autogeek_2009_35463225
Menzerna Nano Polish PO 106 FA is the next generation of Nano Polish PO 106 FF. Nano Polish PO 106 FA contains a micro-fine abrasive dust that quickly removes light imperfections and holograms while creating a mirror shine. This new formula features less dusting than the original Nano Polish and leaves your vehicle with the glossiest possible finish.
Menzerna Nano Polish PO 106 FA is the new and improved version of PO 106 FF. It is currently only available to select U.S. retailers.
i normally mix a little CK red glaze to help the dusting, but if you don't have to buy two products, then this is the way to go!!
How does this compare to Wolfgang Finish Glaze? If they are both new and similar, I wonder does the WFG have the same properties...
3.(PO 106FA) *Finishing 22911 the up-rated version of P0 106FF, this polish is formulated with very finely milled micro abrasives so they don’t require much to ‘breakdown’ and won’t cause surface marring. They have a sharp edge that can cut ceramic clear coats as well as the more conventional clear coats. It has more surface lubrication, which equates to a longer working time and less dusting.
It will remove 2500 - 3000 grit, for surface finishing, cut: 2.5 – gloss 5.0, for LSP ready use a primed White polishing (softer less dense foam (70 PPI) with a light abrasive cutting action) followed by a Blue Final finishing (100 PPI) LC CCS foam pad - 1100 RPM to finesse the finish even more use PO85RD3.02 with a Blue Final finishing (100 PPI) LC CCS foam pad - 1100 RPM
Thanks TOGWT for the information on the 106FA, now i have to save up for this one, because just drop some dinero last night on AG.................:cheers:
Is it true that PO 106 FA has been out since last summer? If so, its not new.
If there are any samples laying around your office Meghan send some to me...............:D
I don't know about it being out since last summer but I've had some for about 3 months now.
It's a very good finishing polish with less cut than PO85rd, but does removes hazy/micromarring with ease and leaves a beautiful finish. I've used it a handful of times and didn't notice that big of a difference between it and FF though.
If it dont require much to break down, does the polish will be more user friendly with the porter cable.
Thanks!
PO106FA has more cut than PO85RD, 2.5 vs 1.5.
