New Opti-Coat Hyper Seal
Status
Not open for further replies.
If it really is dead in 3 days no matter how you try to do the application, you should contact optimum and see if you got a bad bottle. No way a 1 yr sealant is going to last only 3 days and be dead in the first wash unless it’s defective.
I think everything is fine. I can't speak to durability yet. I put a 2nd coat on today. I think a more thorough panel wipe is what made the difference.
The only reason I've avoided a true coating is because I enjoy messing with these spray sealants. I'm getting closer though to trying a coating and will likely at some point.
Last time you killed it, how did it bead during the pre spray? Was it already flat then?
My question is why are you washing it so fast?
Just out of curiosity and to apply 2nd layer.
I would give it a little longer to have the polymers and whatever little ceramic in it to cure a bit before washing it. A second layer with a spray sealant is not really needed.
After this layer I’m going to let it go for a while.
Status
