Had the same problem.
Here's what I noticed.
First, I used the Edge 6" pads and they spun, but if pressure was applied or the edge of a pad came up against an edge of the car, they would stop.
The next time I had a day off, I wanted to try the Edge 4" pads I had, noticed right away, the slightest pressure = no spinning. It was like I had to actually pull up a little to take the weight of the PC off the pad to get the pad to spin.
I then switched to the Wolfgang velcro backed 6.5" pads I had, and now could spin with considerable pressure applied to the head of the machine.
BUT...when I switched to the velcro backed 6" pads I have, same thing happened...hard to get to spin, but not as much of a problem as with the 4" pads.
My conclusion was weight {pressure} apllied to a smaller surface area = less spinning, also the courser the pad, the more apparent the spinning problem due to resistance.
One cannot fault the manufacturers of the pads for the laws of physics, when using a smaller pad, or one of the courser pads, realize less pressure can be applied.
Would be nice though, if the PC had a clutch of some sort to overcome this.
But then that's why the PC7424 is pretty much foolproof in preventing "accidents" to your finish.
