New Product - Lake Country Constant Pressure Pads!
Any word when AG will offer the 4" in the "Flat" faced style?
Are you guys using these more with rotary or DA? Does the layer of softer foam reduce the cut acheived from the more aggressive pads on DA where presure is more needed?
No plans for 4" Flat at this time.
The Constant Pressure Pads are ideal for use on a rotary polisher, but still perform great on a DA. You will have to apply more pressure with a DA to get the desired results.
Thanks Nick. I.was thinking this was the case
Sent from my ADR6350 using Tapatalk 2
What happened to the flat face constant pressure pads? I see they are no longer carried but the CCS version is still there. :dunno:
I check it out all that.Pads are good to use as i use it for two time in my workshop.Good results shown by these pads.Its have a better quality but i,m not sure about it if anyone have a high quality than these pads.
