New Rupes Micro Fiber pad fly off
Valky
Finally I had made a decision to go with Rupes microfiber pad with my MKII 15. Rushing out and brought a new blue and yellow microfiber pad yesterday. Today a new black Merc CLS coming in for coating and there is nothing better to try out these pad. After the first section pass, the result is phenomenal, very beautiful finish and superb cut, it out cut and out finish LC purple thin wool.
Then I start buffing the next section, and after just one pass the pad suddenly shake and then flying off backing plate, luckily I am using very light pressure and in control of machine or I will have a big scratch on this new CLS.
After that whatever I did the pad will continue flying off from my backing plate with speed 3-4, I test polishing with all my other Rupes foam pad and there is no flying off issue.
I move Rupes Microfiber pad to attached with Flex rotary buffer and it's stick on Flex backing plate like a super glue.
What should I do to this situation? My backing plate is clean, it have no issue on the foam just microfiber pad.
I am so in love with this pad and don't want to stop using it.
Odd that the foam pads stick, but the MF doesn't. If it were both I'd hypothesize the plate had gotten heated and the hooks lost some structure.
In any event, happy to send you one of our blue backing plates with the higher grip velcro if you prefer, or a replacement gray plate as a warranty item.
Just shoot an email to [email protected]
Dylan, thank you very much for your quick response, and I am very appreciate your support. But since I am not living in USA, I will try to contact my local dealer first. I did notice this issue since I first get opportunity to play with MKII prototype. That machine have all type of pads flying out. I did mention it to my local dealer but they don't see it as an issue, and thought that it's just dirty backing plate.
But now with my machine, which only 3 months old and buffing less than 4-5 cars, I think this is an issue. I notice that the backing plate have less holding power compare to my Duetto and Mini from the beginning though, just don't see it as a real problem until today.
Still, the result of this MF pad and Zephir is extraordinary for me, it cut Merc clear coat pretty easy and come close to a LSP ready.
Dylan, I met with my local dealer today, he see my backing plate as well as test it and admit that microfiber pad really not going to stick well with MKII backing plate and urge me to buy microfiber backing plate, which make me feel a bit uneasy that I buy a new MKII and rupes system and it's can't be work together. They will ask Marco for what happen.
Question, they are not sure whether the backing plate can be use with MKII or not as it is the original microfiber backing plate from 1st generation. Second will it balance well with MKII?
Both the ES (blue) and MKII (gray) backing plates attach to the microfiber hook and loop no problem. No need to feel uneasy other than you seem to have a unique circumstance. Did you try other RUPES microfiber pads?
As far as the microfiber backing plate, the biggest difference if I remember correctly, is in the weight to help balance the tool IF microfiber is going to be your primary pad of choice. If you are going to use both foam and microfiber, stick with the standard backing plates.
Todd, MKII have come with grey backing plate, it's not my choice. We have test 4 new Rupes Microfiber pad today, 2 blues and 2 yellows, all of them can be push out from backing plate using only one little finger and no force. We also test it on another MKII and it's not sticking with that backing plate as well. Four new pads and two machines should be enough proof that the grey backing plate have something wrong (at least on my production batch).
I still waiting what my dealer can do for me.
Todd, I have a similar issue on my 21 MKII, the foam pads seem ok, nowhere near the grip on my 15 ES though. I tried the Rupes Blue MF just now on my 21 MKII and while its not flying off, the grip is barely there, can be removed from the grey backing plate with hardly any effort.
the mf pads were exposed to sun light, I mean excessive heat?. I have an issue with a yellow rupes pad, I use to wash it and then dry on the sun, and after 2 washes de velcro died.
I put all my Rupes pads through hell, mf and foam. Wash them after every use and never have issues with sticking to the backing plate.
Repeat it again, it's "new" Rupes microfiber pad that never touch anything with the 2 new Rupes "MKII 15" machine with grey backing plate that have problem. Those who use MK1 will never have problem as you using blue backing plate, those who use MKII machine with grey back will have less problem as the backing plate area are larger. I am very familiar with Rupes with never have problem on using them.
I just want to know as a Rupes lover what I am going to do. I buy an expensive machine, buy their expensive set of microfiber pads, all polishes and now I have to buy their expensive backing plate again?
PS. My local price of Rupes is about 20-40% more expensive than US.
Finally I had visit local HQ rupes today. Again we had test the pad on my machine and HQ machine, both of them didn't grab. So the officer open a new in box spare part to test on, it's a grey backing plate. To everyone surprise, the spare part backing plate have a super tight grabbing that require lots of pulling effort to remove pad off.
Now I return home happy with a new grabby backing plate, and my old backing plate might take vacation back to Italy for inspection. For anyone information my trouble backing plate have ended code as B16 and the new one is C14.
Where is the code? Theres nothing to identify on my grey backing plate.
Zubair, take the pad out and see it on the back. There is full code and end up with the last 3 characters
I have a chance to try the new backing plate with MF pad today. With one 2x2 section, MF fly off from backing plate again. All the grip gone with just only one section...
Rupes, you have serious problem with this grey backing plate...
The one you got on 8/20, that was super grabby?
Yes, it's super grabby at first but with only one 2x2 section all those grabby gone...
Now it's grabbing ability is down to the same as the first one with only one trunk polishing....
There are only a few ways to reduce the grip of a backing plate like this:
The hooks become clogged with a fiber from the loops being too soft/delicate or the plate is heated up, warping the structure of the hooks and causing them to lose their ability to grab the loops.
If it happens repeatedly I'd suspect maybe a technique issue - excessive pressure or running the tool wide open which ends up causing a high heat situations.
One of my Yellow foam pads finally gave up the ghost after a 13 months of use. The foam is fine, but it endured both heavy pressure from when I first got it, and being run at speed 6 when my old shroud was worn out.
I'm beginning to think there is a bit more of a learning curve than is precieved.
I'm still playing with the amount of polish needed to reload a microfiber pad, and it's way, WAY less than i imagined.
Even with the PC, I might use moderate pressure at most, but that is much more than the Rupes requires.
Dylan, I am not novices with Rupes. I am very familiar with it, none of my Rupes foam ever have problem, my foam that being use with Duetto for over a year is still in it great form. I am sure that it's nothing about technique. I have trained and having my Rupes certificate, I have my MKII marking to ensure it keep on spinning and never stall. I also putting no pressure because it's not need for Rupes, all avid Rupes user knowing that we use machin to correct, not our power as normal DA does.
Lastly there is no way in this world that new backing plate will melt within first 3 minutes of using, pressure or not is irrelevant here unless they are bad quality products. Sometime you need to admit the design false that could always happen and just correct it.
Not doubting your problem, but if this were a wide-spread issue with Rupes pads you would think we would be hearing about it on this forum and others. Yours is the first time I've heard the complaint of a pad failing within minutes of first use.
