Not doubting your problem, but if this were a wide-spread issue with Rupes pads you would think we would be hearing about it on this forum and others. Yours is the first time I've heard the complaint of a pad failing within minutes of first use.
Could be a bad overseas source? The guy is in Europe, correct? Also, the number on the back leads me to believe that is used for a manufacturer code and date.
I am living in Thailand and not only me having this problem, several customers does, they just can't read and write english that well so you didn't see it here. We did switch the microfiber pads to use with other brand long-throw machine with better gripping backing plate, there is no spinning off from backing plate this time but the loop just came apart instead. I have read that from autogeek forrum and have thought that they already solved problem, seems not in my country.
Again, I have to say I am Rupes fanatics, and these microfiber pad and backing plate really have issues but I still love their cutting ability and finishing.
