New Speed Master Utility Cart and Took Rack
Elliot@Autogeek
Let’s get wheelin’ and sealin’!
The Speedmaster Utility Cart is sure to make your detailing job or hobby a much more enjoyable experience. You’ll be able to quick and effectively work your way around the car without having to worry about constantly running back and forth to grab differently products and tools. The Speedmaster Utility Cart has locks on the wheels to ensure that your detailing supplies don’t go rolling off down the street. Because the Speedmaster Utility Cart has three separate tiers, you will have more than enough space fit every product and tool you will need for your detailing job. The durable construction of the Speedmaster Utility Cart will ensure means that this cart may even outlive your car!
When you are detailing, there really isn’t that much room to set anything down while you are working your way around the car. Setting things on the ground opens you up to the very serious risk of contamination or dirt finding its way into your towels, pads, or products. And setting your detailing supplies down on the paint you just spent all that time detailing is about as counter-intuitive as you can get. Now there is always a table, but then you have to constantly walk back and forth while you are detailing to grab the next product or tool. Detailing is already a time-consuming project, why make it worse?
With three tiers of shelves, the Speedmaster Utility Cart easily holds all of your bottles in place. Plus, look at this tech tip by Mike Phillips - you can hang your Scangrip Multi Match Light on a shelf and use the brakes to park it just where you need it!
With 4 inch deep shelves, your bottles, towels, pads, and brushes won't fall out while in transit - with the Speed Master Utility Cart, you can now become a "mobile" detailer! But not too mobile - The Speed Master Utility Cart also features locking casters to keep your cart where you want it!
Our Price: $175.00
Sale price: $160.00
Keep all your supplies right by your side!
The Speedmaster Tool Rack gives you the mobility you need to optimize your detailing routine and make sure that you aren’t spending more time detailing than you are admiring. The ultra-durable, polyethylene body ensures that the Speedmaster Tool Rack has the fortitude necessary to be used even in an industrial body shop without worry about it breaking. Thanks to the wheel-locks, your tools and supplies will always be right where you left them. The three tiers and separate compartments give you plenty of space to organize and store everything you need, even your drinks!
The Speedmaster Tool Rack gives you the perfect tool to keep all your tools right where you need them, by your side. Unlike your typical tool rack, this one has wheels, meaning that as you work your way around the car, you can take everything you need with you! The Speedmaster Tool Rack cuts down on all the time you spend walking back and forth from your car to your shelf to grab the next pad, compound, or tool you will need.
_______________________________
The Speed Master Tool Rack was designed specifically for detailing! With features such as add-on cup holders (perfect for a bottle polish or a soda!), locking wheels (no runaway carts here!), and polisher neck holders (that's a technical term, right?), the Speed Master Tool Rack provides solutions for problems you didn't even know you had!
Our Price: $125.00
Sale price: $115.00
