Calendyr
- Jun 9, 2013
- 3,996
After watching a few of Yvan Lacroix' videos, I have decided to give the rotary polisher an other try.
I purchased a Milwaukee Fuel cordless rotary today and will start using it as soon as tomorrow.
The machine came with 2 waffle type polishing pads. They look like 7 or 8 inch diameter to me. They are white foam and look open cell so I am assuming they are polishing pads, not cutting ones.
So my questions:
1. What pads do you guys use on rotary for compounding?
2. What pads do you use for polishing?
Yvan promotes the use of the rotary to finish and the Long Throw DA to cut. Since I am trying to learn this tool I will probably do both with the rotary for a while to see how it performs compared to the DA.
His technique is to use no pressure with very little products on a damp pad and setting the machine to minimum speed (800 RPM in the case of this specific polisher).
I have 2 3 amps batteries and I am hoping this will be sufficient to be able to do most jobs. I have not tested how long they last yet, now how long it takes them to charge but rotaries use less power than DAs and modern cordless DAs seems to be able to work almost non-stop with a 2 battery+charger system.
All right, any advice regarding this is welcome. Yvan sold me to the idea why explaining you can get a better finish with a rotary if you have the proper technique, and on top of that it's faster to do.
So my questions:
