got the best invention for $6 tonight at sears. BRASS QUICK DISSCONNECT SET. dont know how i did without? makes a breeze hooking up the hose now.
Hey, quick-connects are the way to go.:dblthumb2: Let us know how those work over a few years time.
If you have any leaking at all, try changing the washers. When they age/patina and begin to leak you can soak them in a harsh chemical metal cleaner, or simply change to NELSON brand. These will last longer than you and I. I always remove my connectors when not in use and place them with my other detailing items.
They also sell plastic re-placement washers for some of these connectors. Some come with rubber washers which will harden over time. The rubber washers are the best, but sometimes "softer" plastic versions can be found as well and they will work well also if you can find them. For these I don't go by brand, but by feel. You can also buy filters that fit where the washers go inside.
I don't know about the quality of these connectors you bought, as I haven't seen them. If they end up giving you problems don't give up on the convenience of quick-connects...go out and buy some NELSON brand...expensive, but worth every penny. They are another product I learned about working in the greenhouse industry years ago...quick connects are not all created equal. However, even if the ones you purchased last you a short time you should be rewarded from their convenience enough for the investment of $6. Sears usually sells good products though.
On the dirty hands (from oxidizing rubber...doesn't have to be in the sun to do this) issue I mentioned, it may be worth your effort to wipe that hose down with a good quality vynil/rubber treatment sold here at AG (If, or dare I say, WHEN it becomes a problem for you and others). I have not tried this with my dad's hose, but it may help to keep the hands a little more clean. May even turn an already lifetime product into an heirloom to be passed to your grandchildren too:dblthumb2:.
