Newbie single stage paint restoration
Plus one for this one interesting to see how others approach removing latex paint.
Have this in mind that I don't know if it's safe to use on your single stage paint! It's depends on what kind of single stage paint you have on the car and what's safe to use on it so you don't dissolves your paint at the same time you tries to take away the latex paint. Ammonia is least aggressive but will need alot of rubbing so don't think it would be good to use. Next is ipa/rubbing alcohol and look if it's save to use on your paint. Then the most aggressive is lacquer thinner this is most likely not so good to use on single stage paint as it often used to thin it out. Then you have Goof Off and the same look up if it's safe to use on your paint. I would test on a little latex paint spot if you can shave it of with a plastic razor. So you have less latex paint to dissolve but look so you don't scratch it up. I know that some cleaner waxes/AIO uses lacquer thinner in them don't remember which ones though. I'm wondering if HD Speed which has petroleum destillates in it would be dissolving and polish it away at the same time. And with the combo of scraped it of with the plastic razorblade. Or test with another AIO you have at home and see what happens.
Hope it helps a little for you to find a solution to it. And again be carefull of what you use and test it first to a very small area that is hard to see.
Thank you SWETN. I am very hesitant to use any kind of solvent.. I know I can get it off with a metal razor blade, because I shaved one of them down VERY carefully and I was able to get it off. That method comes with a major risk of carving into the underlying body paint. I hadn't though of a plastic razor - that's a good idea! Thank you for the suggestion.
Ooops reply was a little wrong there lol.
Totaly understand the cautious with solvents when you don't know what the kind of paint you have. It's alot of work with a plastic razor but if you take your time and are carefull maybe it would work. The benefit would be it can be loosen up a bit when shaving it off. Then maybe the clay can fix the rest. Maybe you can get a more aggressive clay bar like 3M or Meguiars. Or when you are polishing it would clear up I think. Did you feel on the spots after the #7 rubb down if maybe that loosen it up?
3M Perfect-It III Cleaner Clay, 3m 38070, a paint-cleaning detailing clay that grabs foreign particles as it glides across the paint.
Meguiars Professional Detailing Clay Aggressive - C2100
I think you meant to reply to “the bandit” but hopefully he reads this. But I was too wondering how to remove on clear coated cars
I would use laquers paint thinner on a mf towel. Hold a soaked spot on the mf towel to the spot and hold it for a minute or so and then gently wipe forth and back to the spot. Then another clean towel damp with water to wipe all of or rinse. After you are done rinse well and wash it and protect it again.
Step 3: Compound ~ SKIP ~
On Mike's advice, I decided to skip compounding (for now) and start by seeing what I could accomplish with polish alone. Beyond what Mike said in this thread, something I have heard from him and others over-and-over is to:
"Use the least aggressive method that gets the job done!"
Before I started this project, I felt like I had nothing to lose. I wasn't so concerned about being overly aggressive and possibly damaging some areas of the paint,
because I assumed the car would need to be repainted at some point anyway. But now that I've seen the diamond in the rough, I realize I had no idea what was under there. Now I am going to be more conservative with my approach. So let's skip to the next step...
Step 4: Polish
I decided to start on one of the worst areas on the car - the quarter panel. Rain gutters and trim direct runoff from rain or washing right over the middle of the quarter panel, so this area had a considerable amount of chalky oxidation and/or sediment buildup. Some of it came off during the clay bar and conditioning steps, but it was still pretty bad. I started by taping out a test area with blue painters tape to protect the trim.
Finally I could try out my new toy - a Porter cable style 6" dual action polisher. I have used electric angle grinders, die grinders, saws, and other motorized rotary equipment in the past. This unit is very similar in size, design, power, and noise to a 4" angle grinder - it just uses a different head and has speed control. The "dual action" of this unit refers to the combination of a rotating motion (simple spinning, i.e. the pad rotates around it's center) and an orbiting motion (the i.e. center of the pad is moving in an orbit). This combination is what makes DA polishers safer to use than rotary polishers and a good choice for a beginner like me.
I attached a Lake Country 5" backing plate and then a Lake Country 6" x 7/8" white foam polishing pad. The backing plate simply screws on. The pad attaches very securely with a hook & loop system. Next I shook up my bottle of Maguiars M205 polish and put 5 dime size dollops on the pad. Then, with the polisher OFF, I "patted out" the polish to distribute it around my test area. Next I turned the polisher on at a very slow speed to spread the polish across the whole test area. Finally I cranked up the speed and started polishing. I ran horizontal passes, overlapping by about 50%, then vertical passes again overlapping by 50%, and repeated until I had a total of 5 passes (3 horizontal, 2 vertical). I applied only a little pressure to the head of the polisher. Once done, I wiped the polish from the surface with a microfiber towel using linear movements. This worked very well on the non-oxidized areas of the paint, but still left some faint foggy trails from the water runoff. So I went back over it a second time using 6 more passes (3 horizontal, 3 vertical) and the same light pressure.
Here is a video showing the polishing process and the resulting before & after finish after a total of 11 passes with polish.
Here are some before and after "50/50" photos after just the first 5 passes. The right side was washed, clayed, and hand conditioned with Maguiars no 7. The left side was the same plus DA polished 5 light pressure passes with M205. You can see there are still some rain trails / oxidation here after 5 passes. The video above shows the before & after for 11 passes and it's a lot better than the photos below.
I extended the work area to the rest of the top quarter panel, working in roughly 1x3 ft sections, and here's what I ended up with. I haven't yet polished the top few inches of the quarter panel immediately under the vinyl top/trunk/windows. My plan is to use the smaller 3" Griots polisher to do those areas (it's still in transit).
Even after 11 passes, I could still detect some oxidation trails (although faint) near the bottom of this area that don't show so well in the photos or video. So I went back another 4 passes in the affected areas only and this seemed to do the trick - but it was dark and the lighting wasn't great, so I may have to revisit this area when I get back to work. All in all the non oxidized areas looked good after around 5 or 6 passes and the heaviest oxidation required at least 15 passes with light pressure and M205 to clean up. Would it have been better to compound those areas first? I imagine it would have at least been faster, but I don't mind taking more time. I think I will continue to just polish the car and skip the compound step altogether unless I find defect areas that the polish wont fix.
I am very happy with the results. My only misgiving is that the area immediately next to the side trim did not polish quite as well as the rest of the panel. If you have any tips on how best to run the polisher against edges, that would be much appreciated. I tried sneaking up lightly on the edge as well is pressing into the edge, but neither seemed to get the last 1/4" completely fog-free. If all else fails I may remove the side trim in the future and give these areas a thorough polishing.
Between each application of polish, I cleaned my pad "on the fly" by running the DA with the pad in a terry cloth. By gripping the pad within the terry cloth, I was able to transfer spent product and paint into the terry cloth, readying the pad for further polishing. This seemed to work well and allowed me to continue work without washing the pad - we'll see if it's adequate when I do more sections of the car. I learned this method watching Mike's video.
That's all I had time for last night, so I peeled the pad off my polisher and took it to the kitchen to wash. Look at all that heavily paint-tinted spent polish! I am really curious how much of that is removed paint vs. spent polish. My understanding is it's mostly spent polish, but the very small amount of removed paint gives it a strong tint.
Hot water, a little unscented dawn soap, and working the pad with my thumbs took care of that.
Once clean, I squeezed water out of the pad and left it out to finish drying. I only bought one of these pads, so I hope it lasts for the whole car.
For a little more cut you may want to try M205 on your orange pad. it won't be as aggressive as the ultimate compound, but will help cut through that oxidation a little quicker.
That's a great idea! Thank you! I will try that out on the other side and the tail panel. The tail panel may end up needing compound to get rid of the scratches. We'll see!
Cool car and great thread so far. Nice LS in the engine bay!
I received this advice on another forum:
I've polished a lot of cars and a lot of boats... that paint needs compound without a doubt.
Try the compound on the section next to it. Then follow up with the polish. You will cut your work in half and the results should be better.
What do you guys think? Should I try a couple passes with the ultimate compound and an orange pad? I'm curious if in addition to eliminating some of the remaining haziness and speed up the whole job if it might also knock down a little of the orange peel. I assume only wet sanding would do that effectively, but maybe it would take some edge off.
Do 2 test spot behind the back wheel house. 1 with the white pad and compound and then one with the orange pad. And see what you get out of it. I think you could benefit from it. Or the orange and polish or even a more coarse pad with the polish and then reach for the compound.
After experimenting on a few test spots with polish, I took a hiatus from working on the paint in order to focus on other upgrades, prep the car for autocross and enjoy driving the car for a while. That didn't stop me from taking lots of photos in the meantime, even a couple "before and after" from the first round of cleanup described above. Here is a good photo showing how far the paint came from just wash, clay, and no 7 glaze:
Before:
After:
I drove the car like that for the last few months, took it to some cruises and had an awesome time piloting the car at autocross in June.
I didn't want to do any more work until I had time to remove the trim because it seemed like I just couldn't get up to the edge as well as I wanted. The time finally came last week so off I went...
For the most part, the moldings attach to clips like the one pictured above, but before you can get the trim off the clips you have to take off a few fasteners. The quarter molding has one stud at the very back whose nut needs to be removed from inside of the trunk. The doors have screws at the front and rear (total 2 per door) which you can access just by opening the door (no need to remove the door panel. The fenders are a different story; they have studs the entire length that can only be removed from inside of the fender. To get the trim off the plastic clips, I gripped the trim carefully with my fingers and while pulling upward, I pulled/tilted the top away from the car. They sort of unsnapped.
As I mentioned, the fender trim is attached from the inside, so I dropped the inner fender and attempted to take them off.
As it turns out I could get to all the nuts except a couple which were blocked by the cowl. I tried snaking my fingers in from the door hinge area, but there was no way I could get them off without removing the fender from the car. The same held for the "Nova" emblem and decorative "gills" - no way to get them off without taking off the fender. I decided I had gone far enough and I would just have to work around these things. Out the car came for a fresh strip wash.
I think of my car as a "fifteen footer" because it looks and photographs well from about 15 ft, but anything closer and you start to see why I need to work on this paint. Case in point: take a look at the oxidation and/or deposits on the driver's side quarter panel.
With the car clean, it was time to break out the detailing tools again. My goal was to "cut" the paint, which basically means using compound and aggressive pads to cut through oxidation and deep defects. I am using a no-name DA polisher, but I've added a Lake Country 5" backing plate because the one that comes with the polisher is junk.
Shown below are some of my Lake Country foam pads, 6" dia x 0.875in thick. The white one is a polishing pad and the orange is a medium cutting pad. After some experimentation, I decided to go with a more aggressive yellow cutting pad.
For product, I decided to try Meguiars Ultimate Compound. From my experimentation with polish, I decided I wasn't going to get through some of the heavier oxidation and I needed to be more aggressive.
And with that, off to cutting!
Working with the DA polisher is a somewhat new thing for me so bear with me. First I drizzled some compound onto the pad; roughly 4 or 5 dime size drops. Then with the DA off, I pressed the pad against a few places on the car to dab the compound onto the panel, working in roughly a 2ft x 2ft area. Then I put the DA on a very low speed setting (just over "1") to do a quick spread of the compound over the area I'll be working on. Finally, with the pad still against the car, I dial up the speed to setting "3" and move slowly (as shown in the video) in overlapping passes, first going horizontal, then vertical, and repeating. I found about 6 passes (3 hor, 3 ver) with moderate pressure worked in most areas. I came back over some where there was stubborn oxidation.
One thing that really helped was to mark a black Sharpie line onto my backing plate so I could monitor rotation of the pad. Sometimes if I tilted the pad or don't apply enough pressure, the pad would stop rotating and only orbit (the "dual action" is to both rotate and orbit and you want both!) so this line helped me keep an eye on things. Once finished with my 2x2ish area, I turn off the polisher while it's still held against the body (so it doesn't spin freely and splatter compound everywhere), then I go over the panel with a microfiber to remove remaining compound residue. Occasionally I ended up with some stubborn compound residue that was very hard to remove by hand. I found a sprits of distilled water and a wipe with microfiber took it right off. Repeat, repeat, repeat all over the car!
I was blown away at the results of cutting the oxidation off this old paint. It's hard to explain the magnitude of the change, so here are some videos that really show the difference.
Hood 50/50
Door 50/50
Trunk 50/50
YouTube
In addition to the videos, here are some photos. The tops of the fenders were pretty bad - no more!
Trunk chalk be gone!
Quarter panel vs. door.
The edges of my pad got a little chewed up as I occasionally hit the nubs/studs that retain the side molding clips. I occasionally cleaned off the pad to remove spent compound.
I also used a 3" Griots DA polisher in a few tighter areas at the front of the fender with the cyan pads that it came with (got the kit from Autogeek). The polisher worked great but I didn't like how the pads performed. The larger Lake Country pads seeemed to work a lot better so I will have to pick up some in a 4" size.
I was really happy when I finished the last sections and pulled the car out to inspect in the sunlight.
I was exhausted after compounding the whole car. I don't know how many hours I put into it exactly. It took a lot out of me to remove all the trim, door handles, tail lights, bumper, side markers, etc plus tape it off and the actual process of cutting the paint, which included a lot of squatting into weird positions. My body was hurting!
The above closeup is representative of how the car turned out. You can see there are light swirl marks left by compounding which I believe is completely normal. These should be removed by polishing, which is normally the last step before wax.
At this point I ran out of both time and energy to polish the car. I had one afternoon left before a show and I decided it was "good enough" for now. Taking a shortcut, I moved on to wax. I used the DA with a black finishing pad as a wax spreader and applied Meguiars Ultimate Liquid Wax. I applied it to a few panels at a time, then wiped off with microfiber after it had been on for at least 5 minutes (per the directions).
Of course I had to look at it in the sun again. The wax gave it a little more reflection/shine/depth.
Finally it was time to reassemble.
And... drum roll please... tada!
Here's a video... ready to go again!
It was time for the "show". I got up bright and early Sunday morning and headed out at 6am for Supercar Sunday in Woodland Hills.
The car looked the best it ever has and I'm very happy with my progress. The car still has plenty of chips and dings, but it shines! Here's a reflection shot. This should improve when I polish the paint down the road, but I'm still stoked.
My plan for now is to drive and enjoy the car with the much-improved finish, then come back in a few months to polish and wax again. Thanks to everyone on this forum for the inspiration and helpful tips.
Awesome work and write up and pictures!
The paint came alive again. And as you say the shine will go up a notch when you polish it and wax it again. Cars are meant to be driven so enjoy your beutieful car.
/Tony
I'm really loving this post!
Excellent transformation, and all your hard work is really something commendable.
Great work, man!! :dblthumb2:
I've polished a lot of cars and a lot of boats too....
It's always good to get other's opinions or recommendations. My original article on how to restore antique single stage paint, the article you references in your first post of this thread,
I have a 1970 Nova with single stage "black cherry" color paint. I have no idea if this is the original paint, but it is the original color, and it's in pretty bad condition.
I have owned the car for twenty years and never paid much attention to the dull oxidized surface. I always assumed that if I wanted to have a show-ready car, I would have to get it repainted.
But recently I came across Mike Phillip's fantastic articles on how to breathe life back into this paint.
This is the article you reference,
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints
Here's the first few paragraphs... I wrote this in 2010 and when I "write" I always write VERY CAREFULLY. I'm a veteran of the Zaino vs NXT Wax Wars, I never write for the day but always for the future.
As you read the below exerpt, I purposefully made the word IMPORTANT in red bold text. The reason I did this is because there are a lot of detailer experts, especially in the Facebook world that simply don't read but are always willing to shell out their expertise on topics they possibly know nothing about.
Mike Phillips said:
Restoring original and antique paint
In the collector car hobby world, there’s a lot of interest in restoring and preserving original paint on classic and antique cars. Restoring the original paint maintains the overall originality of the complete car and adds to the value as long as the resulting finish is acceptable in appearance and represents how the vehicle would look for its age had the paint been properly maintained over the years.
Hard as it is to believe, people are still finding old cars in barns, storage buildings and garages across this great land and with the right products, techniques and a little knowledge of what to do and what not to do, it’s possible to restore a show room new finish to these time capsule treasures.
What to do
If preserving the original paint is important to you then the first thing you want to do is condition the paint before working on it. Most people just jump right in and start rubbing some type of abrasive compound over old, dry, fragile paint and this will remove a lot of paint quickly and possible remove too much. Instead, take the extra step of conditioning the paint and bring it back to life with product that's been around since cars and thus car paints have been around.
Below I will share the product and actually a technique that may restore your car's paint to your expectations without using any abrasives at all. In the car detailing world we're always talking about the idea of,
"Use the least aggressive product to get the job done"
In this article I'll show you at least one way to put that philosophy into practice.
I wrote my article on how to restore paint for people that OWN the thing they are seeking information about, not the experts shelling out their expertise for cars they don't own. Here's the deal, when working on antique single stage paint that is neglected to the point that it has oxidized, this paint is dry or dried-out and brittle. To follow some people's advice and simply go straight to compound would be VERY aggressive as the dead paint will compound off quickly and this could lead to exposing primer. So "yeah" compounding is okay for antique single stage paint but when you OWN the car in question and it's IMPORTANT to you to do everything you can to preserve the original paint, BEFORE you compound the paint you saturate it with #7 and allow the TS oils to penetrate INTO the paint bringing it back to life and making the paint more workable and safer to work on i.e. --> compound.
You took the safe approach with your NOVA.
Now - let's see the portion where I was typing for the future!
Note the bold blue portion of text.
Mike Phillips said:
What not to do
The first thing most people do when trying to restore an old, oxidized finish is reach for some rubbing compound and try to rub the dead, oxidized paint off the car. While this will work, it's the caveman approach because it's too aggressive, it will remove too much paint and because there's a better, safer approach that will provide a better chance at preserving as much of the original paint as possible which is the goal if you're trying to preserve the "originalness" of the car.
So if you're reading this and you have an old car out in the garage that has oxidized single stage paint, let me share with you a way of conditioning the paint in a non-abrasive way that will make your car's old, tired paint come back to life. Then you can either stop at that point if you like the results you're seeing and apply a coat of wax or I'll share with you how to machine polish the paint to squeeze out even a little more depth, shine and gloss.
I foresaw the masses would tell people to compound antique, single stage paint.
Here's my article on Meguiar's Ultimate Compound.
Meguiar's Ultimate Compound History
Meguiar's Ultimate Compound and SwirlX
Yesterday, on the Autogeek Detailing 101 Facebook Group, there was a guy that said I was a "Salesperson".
I can't even count how many HOW-TO articles I've written over the years.... they are not "SALESPERSON article", they are articles that through the CRAFT of writing and taking and then sharing pictures in a linear fashion can take what's in my brain and put it into someone else's brain so when they go out into their garage the know what to do and how to do it.
:laughing:
Here's my salesman article on that topic...
Video: Mark your backing plate to make it easy to see pad rotation
Your Nova looks great!
Thank you for the follow-up and the pictures, video and descriptions of procedures used.
I'm 100% confident many others will find and read this thread INTO THE FUTURE and your post here for the work you did will inspire them to follow in your footsteps.
:dblthumb2:
