Mike I know you preach #7 for single stage paint jobs.
I wanted to ask you what is the benefit to using #7 over a fine polish like Menzerna 3500 or Menzerna 3800?
Thanks Mike! I did test it to make sure it was single stage (because I was praying it wasn't), and unless I screwed up the test, it is.
The paint doesn't feel rough at all to my fingertips, but with the plastic bag on my hand, the bumps are easy to feel.
I do like the idea of seeing if the #7 does the job as you said. That would be very nice.
If it ends up not removing the imperfections, can I then go back and clay bar it without problems and start over?
I plan to try your plan first anyway. The paint really isn't in bad shape at all.
Does just the first coat need to sit the 12-24 hours, or should each coat be done that way?
Is there a Dodo Juice color you recommend for dark blue paint, or another wax you recommend for this paint?
Mike Phillips said:This is key...
Saturation Application --> The First Application
This is a mostly unknown technique and that is to let the first application penetrate and soak into the paint for up to 24 hours before wiping the product off. The idea being to really apply the product wet and work it in really well and the walk away.
The idea is to allow the heavy concentration of oils to penetrate and seep into the paint for maximum saturation before removing the product and continuing with the process. In this case I finished applying the first application of #7 around 9:00 pm and then left the #7 to soak in until the next day. I started wiping the product off then next morning right about 10:00am.
Some will argue if this works or not but my experience is that with a porous single stage paint it does in fact help. One thing for sure it can't hurt.
Paper Test for Capillary Action
If you place a few drops of #7 onto a piece of paper and then monitor it over a few days you will see the oils in the #7 migrate or seep away from the actual drop of product. It does this through capillary action and the same thing can work to your car's paints' advantage if it's a single stage lacquer or enamel paint.
I placed a few drops about the size of a nickel on a piece of standard printer paper around 3:00pm.
The next day I took these pictures at approximately 10:00am, (19 hours later), note how the oils in the drops of #7 have migrated outward via capillary action.
Feeder Oils penetrate or feed the paint
This same effect can take place in a single stage paint but not only will the oils travel horizontally, they will also travel vertically, that they will penetrate downward "into" your car's paint and this is where the term feeder oils comes from as the oils penetrate into or feed the paint. The result is they will condition the paint restoring some level of workability as compared to just working on old dry paint, and they will also bring out the full richness of color, something that will showcase the beauty of your car's paint.
Just to touch on... Megs #7 is NOT going to take any scratches or blemishes out of the paint. But it WILL rejuvenate the paint, (possibly to where you can then safely polish it).
I wouldn't be afraid of polishing it, you'll LOVE the results.
As far as a "kit"... nothing wrong with buying the pads and buffer as a kit. Just make SURE that you get more than the normal "6" different color pads. DO make sure that you get the buffer with the 5" backing plate, for 5½" pads.
Meguiar's 205 was mentioned because you can buy it in most auto parts stores.
Mike this article is awesome, ill remember till the day i die.
When I was in you class and you showed the class this on the red Lincoln convertible it was one of the best experience in my life, so thank you for sharing with everyone
