This last week, I just saw a few scratches in both vehicles, a day or so after washing. They were very short and straight, and one was in the back door, so its unlikely that this was caused by rocks hitting the paint as I'm driving. I'm not 100% convinced that they were created when I washed and waxed the car, but there certainly is a possibility.
Here is my regimen. Can folks suggest one more/different step, that would be the most likely to reduce future scratches?
I rinse off the car with the shower setting on my nozzle (not a hard narrow stream, but not a "bubbler/soak" setting either). I have a grit guard in my 5 ga bucket. Now my sponge is old, and it is falling apart. I don't have specialy sponges, just cheap Target/Dollar tree sponges. Regardless, I push down on the sponge (when it is in the bucket) against teh grit guard to remove any debris that might have gotten caught, then I turn it over and sometimes push down again, and then pull it out with a fresh load of soap. Most of the time I remember to wipe the sponge in straight lines.
After rinsing the soap off with the hose, I use a Meguiars waffle weave towel to get most of the water, and then follow it up with a plain microfiber towel. When I do wax, I wax immediately after rinsing and then drying the car, so its not likely at all that my waxing scratched the paint.
OK let's play devil's advocate and assume my routine has introduced scratches. What new step would be the best to reduce the chances of this happening again? I know some folks use a two bucket system, but if you are letting debris fall from your sponge into the first bucket, you really shouldn't need a second bucket, should you? If it falls down below teh grit guard, you should be good, right?
