No wax on PPF?
S5mons
We just had the wifes X3 done up with a clear bra (Suntek) and the installer said not to use wax at all. He said to only use silicone sealant/sprays on it. The wax will build up and dry out the film.
Any truth to that? I use the Balckfire wet diamond polymer on it after every wash or when I need to wipe something off of it.
I tried searching, but couldn't find any good info on proper PPF care.
TIA!
There is no issue with applying a wax. I would recommend however to apply a coating over it though
Like a sealant before the wax or you mean coat the wax? Pls elaborate
Sent from my SGH-I747M using Tapatalk
Yes sealant first then wax. I've never heard of wax drying out film but stranger thing are possible I guess. I like the suggestion check with the manufacturer.
It would be best to use something like Opti-Seal so it won't get residue on the seams. Ideally you'd want to use a coating.
No Waxes.
These are the products that
I use on all Brands of PPF:
_________________________________________________
watermark.php
Mothers R3 Racing Rubber Remover, rubber scuff remover, boot scuff eraser
Thanks. That's what I was looking for. The cleaner and sealant is self explanatory, but what is the tar remover for? A pre-treatment for the cleaner or for the heavy residue? I use the 1Z bug wash and like it very much.
Also, any issues with claying or using the buffer?
