yea. I figured as much.
there's a whole lot of little swirls there that didn't want to come out... not at least with what I have on me, and I was too timid to apply anymore pressure than I was.
Yep, looks like rock chips.
Be VERY careful with the pressure though. Removing swirls isn't about putting a lot of pressure onto your paint.
It's more about letting your pads and PRODUCT do the work for you.
thread drift area.....
When I first started buffing paint (for correction) and it was on one of the 5 cars I own, I'd divide the car into bazillions of "test spots" and test each and every pad I had with whatever products I felt like using. My caddy has a hood the size of a queen size bed. That was good for 8 test spots in and of itself.
I wasn't looking to get "correction" but wanted to know what product worked with what pad, with what paint. I spent weeks on a single car sometimes just piddling around until I tried everything I had, (which was more than my share). Now however I have a CRAP LOAD of products, I mean a freaking LOT!!! :laughing:
drift over.....
Be very diligent with keeping up your head speed and watching your arm speed. In fact WRITE - DOWN - what - you - are - doing!
(Not specific instructions, just so you get an idea.)
For instance:
- Area 1; compound used M101, orange CCS pad, machine speed 4.5, 4 section passes, light arm pressure
- Area 2; compound used M101, orange CCS pad, machine speed 5.5, 5 section passes, light arm pressure
- Area 3; compound used M101, yellow CCS pad, machine speed 4, 4 section passes, light arm pressure
- Area 4; compound used Megs UC, foamed wool pad, machine speed 5, 3 section passes, light arm pressure
You get the idea.....
The thing is, the LITTLE differences between speed 4.5 and 5.5 or 4 passes and 5 passes
can make or break what you're trying to do. Then once you have it dialed in you can REPEAT the process over and over and over. You may be amazed at just how little of a difference it makes.:xyxthumbs:
Once you've found the compound stage that gets you where you want to be, THEN do the exact same thing with the polishing stage.
DO NOT expect to get every little thing done with compound and cutting pads only. Not gonna' happen. :nomore:
If you can get to 75%, (especially for a daily driver) then you can finish it with the polishing stage. (
Heck, 80%~85% is plenty enough for most daily drivers.) Especially if you
want, you can hide little imperfections with a bit of glaze and a fine pad after you are done polishing.
It is looking better though. Nothing like the pride you get from doing it yourself, and knowing you are getting better with it as you go. Keep up the good work Erin!
