Correct, I used 1 part 601 to 4 parts 501. Then 1 pt 601 to 4 pt 105. I waited about an hour between those two. According to duraglosses formula of humidity divided by temp times 60 i should only need an hour to cure before wax, but ive seen many people say 12 hours so i figures it wouldnt hurt to wait the 12 hours.
Don't forget 5.5" pads and a 5" backplateI have a 2000 Sienna white. It has been garaged kept at home but at work it sits in the hot FL sun. I have washed it on a regular basis, clayed it a few times and wax it with Eagle One Nano wax every other wash. I am sure there are a few swirls/scratches and the paint is oxidized.
I was wondering that after I wash and clay the car, should I use M80 Speed Glaze followed by some Duragloss 501? I guess I am trying to figure out the differences between the two. Is D501 more or less abrasive than M80? Does it make sense to use both or should I use one or the other?
This car is a single stage paint so I am going to follow Mike's tutorial on removing oxidation from a single stage paint. In this he uses M80 followed by Wolfgang Sealant. Unfortunately, this time of year in FL it's impossible to guarantee enough time for the Wolfgang to set without being affected by water. So I was thinking M 80, followed by DG501 then DG105, followed by some carnuba wax probably Colly 845. How's that sound?
Sorry I am new to this and will be ordering from AG today or tomorrow. I was going to get the PC7424 along with orange, white, and blue pads. Is there anything thing else that's a must have? I don't have a problem buying stuff that I will use but don't want to store tons of product if not necessary.
After the van. I have a White Tundra to do that has little to no swirls and some oxidation. This is an outside truck as it will not fit in my garage. It does get shade by a parking garage while at work though.
As a side note, everything I want to do is for personal use. I won't be doing any cars but my own. Therefore shelf life of products are important.
Thanks
-Michael
Mike, I've never used the M80, but DG 501 has amazing cleaning ability, so I'd use that with a white pad on your DA and top it with 105 and then Colli. You will be absolutely amazed by that trio, I guarantee it!! If you wanted anything to precede 501, you might consider D300 or something similar. Depends on how much time you want to invest.I have a 2000 Sienna white. It has been garaged kept at home but at work it sits in the hot FL sun. I have washed it on a regular basis, clayed it a few times and wax it with Eagle One Nano wax every other wash. I am sure there are a few swirls/scratches and the paint is oxidized.
Thanks
-Michael
Post up the pics when you do!Finally ordered a few gallons of DG products! Can't wait to try them out!!
Plan is to hit my newly swirl free arctic white trans am with some 501 then apply 601 then finally 111 followed by AW. Should be a good one!
I appreciate the comment. I didn't know if using both was overkill. I guess I can forget the M80 ( although Mike used it in his video) and just go with the D501. Or get both, try it on different panels and see if there is a difference in adding the extra step. I can save a ton of time by skipping a step as long as result is there. Both cars have a lot of area. It's not like they are Minis or Miatas. Lots of real estate to cover - over and over.
Anyone else know if M80 is stronger, weaker, or indifferent to Duragloss 501, who has possibly used both products?
Thanks
-Michael
