Mike Phillips said:The Secret of Number Seven
There is a way to restore single stage paints that is non-abrasive and as gentle as you can get using a product that’s been around since early paints were formulated. That product is called Meguiar's Mirror Glaze #7 Show Car Glaze.
Thank you!
Stoneraizer, I'm personally not a fan of using glazes, yes they enhances gloss and depth however their filling properties are what prevent me from including them. I guarantee removal of defects, including glaze would lead to question true correction or not.
This probably doesn't apply in this case, as I believe this is geared to older, more fragile, and lacquer ss paint. Any way thought I'd share it:
I totally agree with you, I am NOT a fan of using glazes either (for the same reason you stated). I did however what to point out that many people like to use #7 to nourish and restore oils back into neglected ss paint before correcting the paint...There is a technique in which # 7 is handed rubbed into the paint, and allowed to soak into the paint for many hours (12-24) before removing. Then additional rounds of #7 worked into and removed. Then for those of us like you and I who want to remove swirls (not mask them) the normal paint correction process begins...
BTW: Great job, very nice save!!
I understand where you're coming from and have known that information, I appreciate you clarifying it! I used this process on a 1963 original paint Corvette, applied a few coats and let it soak in over the course of a few days.
However, do not feel that is needed on much newer vehicles like this one. While it may not be a bad idea to nourish it, it's just not a common practice of mine!
