OK, I finally got to try some of the stuff I recently bought:
OCW vs NXT
OCW was very easy to apply. Tried two methods: sprayed directly on paint and then spread with a mf applicator -and- sprayed mf applicator and then spread on paint. Both yielded similar "evenness". I then immediately wiped off with a mf polishing cloth. This seems to be a truly wipe on wipe off product. If I let it dry at all, it streaked or spotted. I got rid of them by reapplying on the same spot and wiping off right away.
NXT liquid is a little more difficult to apply thinly by hand. I probably just need practice. I usually go with the PC and grey pad to apply and then buff off with a mf cloth.
BTW, is OCW supposed to have a very, thin, watery consistency? I was very shocked by this. I thought it would be more like a slightly thinned liquid wax...not watery.
Optimum No Rinse as a QD/clay lube
This is based on my experience with Meg's Quik Detailer and Clay Magic clay lube.
Pros:
Grit Guards
I use two rinse buckets (1 for each side of car.) I put one in each bucket and then filled them to a full 5 gallons. Both grit guards floated to the top as I filled the buckets.
I had to push them both down to the bottom and they stayed down after that. I guess they did their job. Weather permitting, I'm washing both vehicles approx once every 1 to 1.5 weeks. The water is never really dirt. I didn't notice the water at the bottom being any darker than usual. I do like how I can drain and dry my wash pad on top of the grit guard. I'm not sure if they're providing any real benefit for me other than some piece of mind...at least they weren't that expensive.
- Optimum Car Wax "spray wax" vs NXT liquid and spray wax
- Grit Guard
- Optimum No Rinse wash (as a QD and clay lube) compared to Meg's Quik Detailer and Clay Magic clay lube
OCW vs NXT
- Application - OCW is easier
- Slickness - NXT liquid
- Removal - NXT (since you have more work time.)
- Smell - OCW (pina colada)
- Durability - NXT is 4 weeks max. OCW - we'll have to see...despite numerous raves, I'm very skeptical that such a wipe on wipe off product could leave enough behind to be durable.
Pros:
- Slicker than Meg's QD
- Doesn't dry as fast in full sun as Meg's therefore less streaking
- Very economical (6 ounces to 1 gallon of water.)
- No added glossiness despite advertising claims.
- Not as slick as Clay Magic's clay lube....(strange because you mix a stronger solution for the QD than you do for the clay lube.) The ONR as a clay lube would not be sufficient to make me feel comfortable using it.
Grit Guards
