Oil field truck
Coopers ST
Hey all,
I booked a 2016 pickup truck for Tuesday that has lived in the oil field. The interior is not bad, it had seat covers that I will just toss per the owner, and weather tech floor mats, so really it will not be terrible. The outside though has more than just mud on it. It almost needs a degreaser or something. What should I spray on it that will be paint safe before my clay polish and sealant? Would just Sonax or something like it work, or should I spray an APC?
thanks,
Brad
Tar X is a good choice as well as iron x. Maybe mix in some apc to your wash soap or ssomething. Another good choice is to hit the car with zep 505 as it's an excellent degreaser and then use apc with car soap in your wash bucket.
Id try stoners tar minator. Cannot vouch for it with no experience but have heard good things about it. Id personally foam soak with an apc and soap, then spray tarminator. maybe then an iron remover then rinse those two off then clay
I love tarminator it works awesome
Probably has driling mud and other chemicals used in driling process on it. This is where I put the rinseless down and hook up the pressure washer. A good pre-soak with degreaser will benefit you here big time. Foam gun/cannon pre-soak after as well.
Thank you all. I have no idea what is actually on it and told him no guaranty it will all come off without some permanat damage to the paint but I will give it my best. He is fine with that.
The only thing I don't have listed above is tarminator, is it available locally at all? I do have a gallon of bug squash also, I wonder if that may break down some of what's on the truck. Unfortunately I didn't think of taking pictures just quickly looked at it. He said he was going to take it to the spray n wash before I got it so maybe some of it will be off.
Tar X and Iron X come in a single product called TRIX. According to the CarPro advertising, it is full strength Tar X and Iron X in one product. Might take more than one application, but this might be the best to go with as it should remove iron and/or oil/greasy contaminants in one spray.
Hey all,
thanks,
Brad
I found poor boys bug squash diluted to work great for this situation. Not really a poor boys user but they have a home run on this product.Bought 3 gallons of this week alone.Needed to find a product to use underneath jets and small private air craft.The underside of these planes are covered with oil and it's really thick.Was using paint thinner to remove prior,but bug squash cuts right through it spray and wipe.Great product and super cheap.
Just don't let it dry on the paint keep it wet all the time.
I had a lot of road tar from oiling down dirt roads and I filled a garden sprayer with kerosene. I let it sit on the paint for about an hour then washed it off. Repeated once more with the kerosene and then washed and polished as I would normally.
I had previously tried various tar removers and it cost so much in material that I switched to kerosene.
^^ this or mineral spirits. I personally work it in sections due to safety. Hood-Roof-Deck, then front clip, rear clip and then sides. Spray, let dwell, wipe necessary areas with a MF Rag, rinse/wash with plenty of soap. This is about the only time I put some dish soap such as dawn in the wash bucket mix to help separate the grease. Rinse.
Gas will dissolve tar quickly as well.
I would only use gas for spot treatment of tar. Be VERY aware of gas fumes. It's not so much the liquid that is flammable, it's the fumes that are explosive. You can spend hours watching you tube vids of people and camp/bon fires.
Regular griots garage pink carwash soap with an ounce and half of APC mixed in bucket. I ended up spraying bug cleaner first to soften up the oily spots. Once washed clay and hd speed.
Good to know it doesn't take much to deal with the issue. I wonder if bug cleaner was necessary or vise versa.
Bug Squash is a great substitute for Citrus Power. CP is effective, but holy crap it's expensive for the amount you get. I haven't found the need to exceed 1:3, as it's more than enough to deal with dead bugs and a week old traffic film.
I don't know if it was 100% necessary in the amount I used. I tried without first and some spots needed extra scrubbing to get clean. It was easier to spray a panel like you would spray wax or QD than just spot spray it. With that done it cleaned up like normal wash.
Thank you for the quick rundown. Should I run into a similar situation, I will take the same approach.
