Mpower4life
- Jul 28, 2011
- 11
OK so I have done what I have thought to be a lot of research. I have "detailed" quite a few vehicles now but I must say... I am not happy with the results as far as paint correction goes. Long story short, I have a PC 7424xp, Flex 3401, and a GG 6". I have the LC pads (CCS and Hydro), uber pads, surbuf MF cut pads. I have been using M105 for compounding or if I use the MF I use the D300. I have various Menzerna polishes as well to follow up with and M205. I am doing the motion that everyone says is proper. Each time I get excited as I follow peoples write ups and what they have done to what appears to be a perfect finish, I am always disappointed. Where is this whole, "you can correct paint almost to perfection with a DA polisher" notion coming from?? I have not yet been able to achieve this and am getting very frustrated and disheartened with the process. Ultimately what I guess my question is what am I doing wrong? Am I not spending enough time on the process? On a car that is in pretty bad shape, how long relatively would it take to get these results in the paint correction process? Am I better off taking the plunge and start practicing on some junk hoods with a rotary? Keep in mind, most cars I'm working on are full details so I am spending quite a bit of time on the interior. I've heard guys say they can spend 20+ hours on paint correction and i've also heard much less. SO, with that said, how long should each section (2x2) take? how many passes is realistic? Or is it just a must that pretty hammered cars need a rotary or even a wet sand to get the desired results. Any help here would be great... cough* (Mike P) *cough.
