y8s
- Sep 12, 2012
- 331
- Thread starter
- #21
Are you using a dedicated trim sealant/protector...or OCW/OOS?
I didn't get that far. Right now it's unprotected.
I did not tape off the front fender trim because a post suggesting that applying poli-seal to trim before opti-seal was a good idea. It isn't. At least not with a DA. It left the trim a little whitish. I cleaned it off with power clean and it was back to normal.
I did wipe some opti-seal on some isolated trim pieces (cowl, rear diffuser) to see how it looked. I am happy to report that the intial appearance is just as one would hope: SLIGHTLY darker in appearance (almost not noticable), matte, and even. You wouldn't know it was there if I didn't tell you. We are expecting rain today too so I will see how it really performs.
I would kind of like to be able to add some "trim darkener" if possible to keep blacks black on those big plastic wheel arches, but if the opti-seal merely maintains and enhances the OEM look, I might just use it and nothing else. I also understand that the opti-seal will migrate below whatever else I put on there anyway so it would just require reapplication of the "trim darkener" at some point anyway. If I can get away with opti-seal and OCW on the whole vehicle, that'd be easy and awesome.
