Maybe one day I will be able to afford that gloss meter Paul....
As for the smaller backing plate on the 21:
I asked Todd about it, he has asked RUPES about it. From what i gathered, you do not want to change the backing plate on this machine. The motor is extremely sensitive to weights, rotations, pressures. If it senses too much rotation or imbalance, it will try to slow itself down or reduce torque. This means you will
not get more correction out of the 21 with the smaller backing plate.
Todd does use the washer mod however, which i have not tried
Paul have you tried the washer modification?
Think of the difference in sizes of the LC Hybrid pads on the Flex 3401. The 6.5 inch pads are far too large to correct an entire car (truck... maybe). The 5 inch Hybrid pads make a much better choice for full vehicle correction. Not only do they work faster because of the smaller size, they will work better on contours. That is why I would choose the 15 for DIY. While the 21 might be able to correct flat, horizontal panels marginally quicker. It will not correct an entire car quicker or better.
Link to the washer mod (other forum content):
http://tinyurl.com/a79t93g
