Junkyarddogg
- Aug 12, 2014
- 28
When using this, it seems most use just one bucket. How do you keep the sponge from getting too dirty? What's the method? I've been using microfiber towels but the sponge seems easier.
Even though Optimum recommends one bucket with ONR and the BRS I use two buckets. I have trouble placing the sponge back in filthy dirty water and then washing paint with it. Using two buckets keep the wash solution and the BRS sponge clean . On my personal cars I only use one bucket since the cars are always clean. When cleaning customers cars that are filthy I always use two buckets. I can't take the risk
OK thanks guys. The grit guard, are you supposed to rub the sponge against it?
Today I washed with the BRS and one bucket. When I went to dry off with the waffle weave, it still had dirt on it.
Did you at least hose-off or power wash the car before using the BRS??
If you have a pressure washer and access to a water source, what would be the advantage of doing a Rinseless Wash over a traditional wash with car soap and a wash mitt?
3. Rinseless wash wet car. Use DI water in bucket and GDWM. Don't dry panels as you go along - it's a waste of time. Use DI water, and wipe streaks off when done WITH QD (car is already 90% dry from evaporation).
Since you use DI water, any "spots" easily wipe off. They will just be left over polymers from the RW solution - not dried minerals.
I've never thought of this. Do you think it'd work washing outside too. I'll try this way next wash. Sure would save time
I like how you do it.****
1. Most rinseless soaps seem to add some protection, not take it away like conventional soaps.
2. You can use a small quantity of DI water to to do RW after pressure washing, making drying much easier.
3. It's faster, especially if you use something like the GDWM after pressure washing. No need to continuously rinse soap off the car and wring out mitts - just throw your towels in the wash.
4. It's easier. You can do a RW with one bucket with like a gallon of DI water doing GDWM - much easier than dragging 2 X 5 gallon buckets around a car.
Anyway, this is how I do it:
1. Clean wheels/wells/exhaust tips traditionally with bucket, pressure washer, various brushes/tools, etc...
2. Foam car and pressure wash off foam. If sun is out and I'm working outside - final rinse w/ DI water.
**** I've been using this method pretty much exclusively on my black BMW for years now. I can tell you it works very well, and doesn't cause any marring.
Did it last night...
