chilly
- May 13, 2006
- 3,363
- 1,450
Fine for a cleaning of coatings and would use before a sealant or wax but i wouldn’t say it’s a panel prep. Definitely wouldn’t use this only before coating.
Panel preps are either Solvent, Naphtha or ISP based to remove waxes, sealants road film and such.
I believe this particular product is a Alkaline based cleaner….. will clean well but won’t completely remove the for mention things on paint.
Works great on coated cars though.
All I have to go on at this point is the information on the thread I mentioned
I will give it a go and see how it works as both a strip wash for sealants and coatings and a panel wipe
I don't do coatings, I play with spray sealants and waxes
Worst case scenario is it doesn't work and then I just roll the gallon of panel wipe I make back into wash solution and fall back on my current strip wash
Or I could try it as a panel prep and then follow it with a homemade IPA spray as a final wipe
All in the name of science
It's cheap enough that if all it does is remove all the road film and crap as a plain rinseless wash and leave nothing of itself behind then that's fine too
We shall see
