Chris Thomas
Optimum Guru
- Dec 21, 2007
- 1,824
Hi All,
I recently got a PM asking what the smallest compressor necessary for applying Opti Bond was. Because paint/air guns use a large quantity of air, you really need a 10-20 gallon model that can continuously produce 40-60 psi. If this is not in the budget, I have an alternative for you.
The Wagner Control Spray only needs electricity to operate and does a very nice job with dressings thinned 1:1 with water (like Opti Bond, or Protectant Plus). The tip can spray a fan or cone and coverage is controlled by changing your distance from the surface. I picked mine up before I had a compressor and it has seen 3+years of service without a problem. You do not need to clean it after each use and the container is suitable for storing the dressing without issue. I know they are sold at Lowe's, but mine online was $39.
Here's a pic:
Here's a pic:
