Hi,
Just put a coat of Optimum Gloss Coat on my VW Golf and I put it on way too thin.
I followed the instructions on the container of a few drops per panel. I only used 2.5ml which probably nearly got all absorbed by the applicator anyway.
So the new plan is to apply drops per panel. I have split the car into 24 equal sized areas, but need to understand roughly how many drops per ml.
I have read both 20 and 60 drops per ml in my google searches.
So at 20 drops per ml and 7.5ml remaining, I would use 6 drops per section, but at 60 drops per ml, I would need to use 19 drops - quite a large difference.
Has anyone roughly counted how many drops they have applied to a small car, or how many drops per panel ?
Also, I have 10ml of Opticoat 2.0 that I have saved up for my new car, and assume that drops per ml is the same as Gloss Coat ?
Drops measured using the blue needle that comes with the Gloss Coat, they are very small
thanks
Digger
thanks
Digger
