For me, it's not about the suds...it's the ease of rinse. I don't want something that is very difficult to rinse off the car. That foam booster will take forever to rinse off...plus it's nearly impossible to rinse it out of the bucket when your finished.
More than likely need a certain % of water to make the foam booster miscible. Just give it a good shake and add immediately to your wash bucket. The two solutions are not miscible as is
Then I add the soap in the corner. Always try to add it to the water and not on the mitts. Btw the dilution ratio on this soap is a bit oddball and therefore annoying and hard to pinpoint when adding/pouring straight from the bottle... I mean who the heck adds soap by the half oz? I might be nitpicking, but who can eyeball in .5oz. increments? I probably added more than recommended, because my brain is wired to pouring full ounces at a time...
You could use the cap on the bottle for measuring. It's equal to .5 oz.
I might get lambasted over this, but quibbling over one half of an ounce of product is nuts.
If it calls for 2.79 ounces per gallon (just an example), 3 ounces it is.
Done. Stop with the minutia.
Sounds promising... I once tried rinsing out an empty small bottle of Carpro Reset because I wanted to reuse the bottle but gave up after about 5 tries because it seemed like the foam was never going to end.
What are some soaps that you guys would consider to be hard to rinse? I’ve never experienced a soap that I’d deem hard to rinse. Even way back 20+ yrs. ago I don’t recall dish soap being hard to rinse off. Also, does using a power washer play a factor in regards to a soaps ease of rinsing?
Eldo, great review!
Is it possible those mitts had any rinseless wash residue in them?
Megs Hyper Wash although much slicker and sudsier, is much harder to rinse off than Optimum Car Soap...in my opinion.
This is what I needed to know.
I had entertained the idea of buying HyperWash but I can not fight with the rinse.
Reset doesnt bubble any better than OCW in my opinion.
Honestly they both feel the same when sliding over the paint. Reset has a thin consistency and OCW is like syrup out of the bottle
Good deal, I saved over $30.00 today
But the itch no doubt will have me buy Hyperwash by the end of summer.
I’m not sure if you’ve tried Carpro Reset, but when it comes to car soaps and there being any significant difference that sets any of them apart from the rest it’s probably the only 1 I’d actually put in that category.
It checks every box.
Lubricity [completely blows this soap out of the water]
Suds [again, it’s almost like comparing a rinseless to an actual car shampoo] Even when compared to car soaps with great suds, Reset manages to have even better suds.
Scent [good enough to be considered great scent]
Dilution ratio [1oz per wash bucket]
It’s clear [if that matters. I’m sure there’s people out there who like the fact that it’s colorless]
If you haven’t tried it yet I’ll go out on a limb and guarantee you won’t be disappointed with it.
