r_wain
- Jan 22, 2007
- 421
Bence said:When an Optimum polish is hard to remove, 1.) you have used way too much or 2.) you didn't break it properly down.
Even with my short throw DA (2 mm), Optimum polishes can be broken down in 1-2 minutes on speed 6.
Two pea sized drops on a 16 cm pad is totally sufficient (OP/OC). OHC is runnier but the dosage should be similar.
:iagree: 100%. I have had nothing but good results from OP and OC once I started using the correct amounts. I have never had problem removing it though.
