Capa1970
- May 22, 2011
- 494
This weekend I was excited to try some of my recent purchases from Autogeek. For the first time I tried Hydrotech pads. I used them with Duragloss 501. I had always either used the flat pads or the CCS pads but have a new favorite now.
I also got a chance to try Optimum's mf cutting discs and also for the first time Meg D300. I had purchased two discs and used them on my mid-sized Lexus GS400. The vehicle had, just on the hood, some water/acid spots. I taped up the hood and divided it into 9 sections. The Griot's DA was on speed 5 and, with some pressure, I tested the first section. The spots were still there and so I bumped the DA up to 5.5 and redid the section. The spots were still visible and so I just assumed that they weren't coming off without removing too much clearcoat or paint. When I finished the second section I noticed that the middle of the pad was gunking with the product, despite using 3 pea sized dots of D300. I spritzed it with some water and massaged the pad to soften the middle. I then switched to my second mf pads and did 2 sections before I had to spritz it with wated again because it gunked.
After finishing the hood, I decided to try the discs on the headlights. I taped it up and on the second round on the first headlight the disc separated. It was the microfiber part from the foam and not the other side that is on the Lake Country backing plate. The other disc finished both headlights but I noticed after detaching it that the part that attached to the backing plate had started to melt/burn. I also noticed that the backing plate has a dimple on it, presumably from applying too much pressure on rounded surfaces. I am disappointed with the mf discs but am wondering if I did something wrong?
