Anyone using Optimum Hyper Polish Spray with a 15 or 21mm polisher??? Curious how it performs.
I like the ease of use of this panel wipe, but find it too strong on some paints, which creates hazing upon wipe off.just be sure to do a good wipe down on a test spot with Gtechniq Panel Wipe or similar.
I switched to Gyeon and like it better.Interesting. Have used it a few times, was thinking of switching grom Gyeon Prep.
Did notice that when using it, need to work in smaller section as it seems to evaporate or haze if applied in too large an area.
With Gyeon or WG Prep, can hose down some pretty large sections with no apparent ill effects.
Gtechniq sure burns more than the others if you get it in a cut on your hand.
Does Hyper Polish contain fillers or just allot of polishing oils?
