Vegas Transplant
Active member
- Oct 11, 2011
- 4,447
- 3
I destroyed two Optimum mf pads (first use) just on the hood of my car. I used a Griot's and speed 5 and switched pads per section. I had separation on one pad and the other pad on the back showed evidence of light melting and part of it was black. I was using D300. I was very disappointed but apparently the machine should of been on speed 4 (which on a Meg's isn't enough and on a Griot's does not seem to be enough).
From all of the posts, from all of the threads that concern pad separation and melting when using a Griot's - whether foam or microfiber (a) too high of a speed setting (b) Product over-saturation (c) too much pressure.
These issues are well documented on the forums, and should monitored by every Griot's user.
And, if all three were in play, the end result is always the same.
Other variables would be surface temps, direct sunlight, tool used for cleaning pad (brush).
What issues were you attempting to correct?
What did your test spot reveal?
